Old 07-17-2014, 02:57 AM   #1
1969 27' Overlander
Esbjerg , Jylland
Send a message via ICQ to Luc_DK Send a message via Skype™ to Luc_DK
AS Overlander 1969 Broken Wing Window
Hi Air Forum
On our last trip a window broke on our 1969 Overlander :-(
Front Wing Window (right side (curbside))
i can buy a new Window(plastic) with frame in the US for 500 $ + shipping + Tax (i live in Denmark (EU)) total cost 900 $
pretty exspensive and "hard" to install. the new frame is bigger, so i have cut in Airstream to fit it !!
so i will rather look for a local shop that can work with lexan.
Can i change the glass/lexan without taken the frame off ?
from the inside maybe ?
or do i have drill all riverts out ?
if i have drill all riverts out, how do i install it again ?
i have tools to "normal" riverts, but how do you install riverts on an airstream ?
are they called olympic riverts ?
is't ok to use lexan instead og tempered glass ?
the glass is marked with:
Corning
AS 2 SOLID
Chemically
Tempered M2
Safety Glass
which type of lexan should i use and what about the thikness ?
Now i found out the (hard way) why many have AS have a rockguard in front, i thought it only was due to the Sun...
i think i need a rockguard.
i hope someone will share they knowledge, Airstreams are a bit rare in the EU, so its hard to find repair shops and help.
regards
Peter
Name:	Rotation of Rotation of foto (2).jpg
Luc_DK is offline   Reply With Quote
Old 07-18-2014, 08:25 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
69 wing windows are square cornered on the lower outside corner. this was the only year Airstream did this so original 69 replacement windows are extremely hard to find. Lexan (polycarbonate sheet) can be used as a glass replacement. I would use the hardest you can find of the same thickness as the glass. The perimeter rivets have to be removed to get the window frame apart. There should be some screws in the corners holding the frame together, and they most likely will not remove easily. Soak the screws for several days with a good penetrant tapping the aluminum around the screws to break down the inevitable corrosion. Cut and fit the Lexan window into the frame and replace the corner screws. Rivet the whole assembly back onto the trailer.
Post more questions as they asrise and take it one step at a time.
1969 Overlander Roadside Window broken Aubiexx 1965 - 1969 Overlander 11 05-29-2014 01:51 PM
1969 street side curved Wing window for sale? Jake_Seipel Airstream Classifieds 0 05-11-2014 07:06 AM
Broken wing window loechli Rock Guards, Segment & Window Protectors 3 08-10-2010 11:17 AM
Curbside Wing window and window by door L&R Rock Guards, Segment & Window Protectors 5 07-07-2009 10:45 PM
