Hello all.
I am trying to get the lock cylinder out of my bargman l100, to see if I can remove the slop. I know that there must be a pin that holds it in. I have tried the diffrent spots rotating it with the key, and useing a shim from the front to see if I can find the pin and release it. What am I missing?
1997 25' Safari
1973 25' Tradewind
Greenville
, South Carolina
When looking down into the brass cam of the lock while holding the outside handle in the palm of your hand you will see one of two things. First a small weld tip or head or a phillips screw. If it has a small weld and it has worn down then I don't think there is anything you can do unless someone here has modified the tip to place a screw in the tip in order for it to be tightened. If it has a screw then just tighten the screw and that will remove or reduce the play. You do not have to remove the lock cylinder to do this. Attached is a picture of the lock with a screw in place. You can see it dead center inside the brass cam.
Rick
Thanks for the reply. I have one of each. I took the one of my Trade wind last night and it had the screw. which was lose, also the lock pin was lose in the hole. I prick punched the pin and put it back together, seems better. The other one I have is a spare, and I have in my mind to rebuild it. I am a machinist by trade so parts can be made. I want to get the lock cylinder out to see whats there. Thank again.
1997 25' Safari
1973 25' Tradewind
Greenville
, South Carolina
There is a posting somewhere on the web that somebody posted where he had removed the lock cylinder. I was surprised because I thought it couldn't be removed at that time. It was either here or on the Shasta or Scotty forum.
I have the Rebuild kits for these locks if you need one.
