Old 05-31-2014, 02:54 PM   #1
rochar3's Avatar
2003 31' Classic
Valparaiso , Indiana
align screen door
Help,
My screen door on my '03 31' classic is out of whack Gaps at top and bottom. How do you adjust? Try to bend door to fit or bend hinges to adjust? Hinges are riveted and there does not seem to be an adjustment. Anybody have any ideas?
THANKS, BOB
Bob-air # 657
I can win any argument on any subject. People know this and steer away from me at parties. Often as a sign of their respect, they don't even invite me.
rochar3 is offline   Reply With Quote
Old 05-31-2014, 03:48 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
While my readjustment was for the outer door you may want to consider the same approach. Cut a piece of wood to match the contour of the door frame. Then you will have to add thin slices of wood one by one and clamp. repeating this addition till the door matches the frame. You have to OVER BEND the door in order to move it to the correct form. When adding each slice of wood you have to plane them to give a smooth curve leaving the high spot where you wan the greatest bending.
Note the original dark board and the additional thin slices of lighter wood with the high spot about at the door latch.
This is an early picture in the process. I had to add several additional 1/4 in. pieces to get the final curvature.
2004 Excursion 4x4
Old 05-31-2014, 06:03 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The screen door is considerably lighter and more flexible than the main door. You can usually just take open side of the door and give it a little attitude adjustment. Technique #2 is use a wooden block and a hammer. This may work better for the hinge. You may pop a rivet or 2 but they are easy to replace. This is a case where my personal motto "If it doesn't fit get a bigger hammer" may not apply well, but as Howie says you may have to over bend it a little.
I once saw an Airstream Factory video on door adjustment. First they made sure the owner was not around. Then they got out the hammer. Then they gave the owner the bill but that part was not in the video.
Old 05-31-2014, 08:21 PM   #4
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 06-01-2014, 07:52 AM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
Yeah that's the video. Quote "so you can see some of the things we're usin we may not really want to use in front of the customer. This is his baby. The customer comes out and sees us beatin on doors".
'solar screen' replacement window screen jrsygrl Windows & Screens 3 06-23-2010 03:56 PM
Hehr Standard...To screen or not to screen soldiermedic Windows & Screens 10 04-23-2009 11:45 AM
Fixing screen door screen wacnstac Windows & Screens 8 04-09-2007 10:35 PM
Door hinges & new screen door? JKWoodrow Doors & Locks 5 11-17-2006 09:39 AM
Weather seal for '57 door and screen door cdmagda Doors & Locks 0 09-01-2005 09:40 AM
