Old 12-21-2018, 05:22 AM   #1
2014 27' FB International
Samaria , Michigan
ac vents falling out
My 2018 international 30 ceiling ac vent fell on me in the middle of the night while using the heat pump, this happen to anyone else? Trailer has been great for the first season, couple minor issues but airstream sent parts and easy fixes, but these vents have started falling out, next was the bathroom then one forward, drive slow on bumpy roads and no popped rivets ect.
First325 is offline   Reply With Quote
Old 12-21-2018, 07:06 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have a 2015 Flying Cloud 25FB (Lucy) that we purchased new in October of 2014. This was the first year of the ceiling vent air conditioning. The original vents were covered in a screen mesh in a metal ring with no directional or cutting off capabilities.
When Lucy was about six months old, we had her at Jackson Center. Airstream replaced the original vents with the directional vents now in use. These new vents are always falling to the floor. I have tried several fixes including using two-sided tape around the outer plastic ring of the vents. This has worked somewhat, but is nopt a surefire fix. We still have vents fall, especially when we use the heat pump.
These vents are the product of a flawed design by Airstream.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 12-21-2018, 08:35 AM   #3
UncleBad's Avatar
2019 16' Sport
Oro Valley , Arizona
Your not alone First325. I have thought about using a few (small) pieces of double sided tape to stop the attacks from above.
Moosetags - do you happen to still have your old type mesh vents? PM if you do! I have been looking for a few.
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
UncleBad is offline   Reply With Quote
Old 12-21-2018, 08:45 AM   #4
2016 26' Flying Cloud
Southlake , Texas
A couple of things to fix this. 1. Look carefully at the hole in the ceiling. All mine has a little aluminum tab sticking out. Cut or dremmel those off. 2. Get a heat gut and carefully heat the plastic clips on the vent outwards so they fit tighter. 3. When installing the vents, get something to fit between the aluminum grill and the plastic part with the clips. Push up on the plastic part until you hear the clips “snap” into place. Problem solved.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Southlake, TX
WBCCI
Bgibbs is offline   Reply With Quote
Old 12-21-2018, 08:50 AM   #5
Mollysdad's Avatar
I had one falling out and the dealer had a fix. Not sure what they did, but it works as expected. I think there's some tabs that are supposed to hold them in, but get bent in installation.
Mollysdad is online now   Reply With Quote
Old 12-21-2018, 09:04 AM   #6
2017 28' International
Baileys Harbor , Wisconsin
Brian
I got some clear silicon sealant and put them around the vents where they came in contact. 3 of mine use to come down while traveling all the time. Issue solved. Cheap and easy fix.
Daquenzer is offline   Reply With Quote
Old 12-21-2018, 09:17 AM   #7
Sharpsburg , Georgia
This is a known defect in Jackson Center. They have a fix with screws that cure the problem. I had my local dealer try to fix but they weren’t successful, but the factory has the correct fix now.
jreets is offline   Reply With Quote
Old 12-21-2018, 10:00 AM   #8
2017 25' Flying Cloud
Queen Creek , Arizona
Replace them?
Take a look at this thread.
http://www.airforums.com/forums/f542...rs-166383.html
QC TORPEDO is offline   Reply With Quote
Old 12-21-2018, 10:13 AM   #9
1978 31' Excella 500
Barrie , Ontario
I have a 1978 31' have pulled it thousands of miles and no popped vents or rivets!
Bev1940 is offline   Reply With Quote
Old 12-21-2018, 10:14 AM   #10
2018 30' Classic
Birch Bay , Washington
We had a number of vents that would fall out—problem was fixed by putting 2 or 3 dabs of silicone caulking on the vents.
mdaley21 is offline   Reply With Quote
Old 12-21-2018, 10:21 AM   #11
Lebanon , Tennessee
Looks like an RJ9 connector. So in addition to controlling the awning, it will pick up all verbal discussions within and without the RV and transmit to Facebook, which in turn transmits to companies in the US and China for analysis and tracking. If you say anything negative about Individual 1 from either country, a drone will be sent out and your vehicle computers will be over ridden, resulting in your having an accident. This message will now self destruct in 5 seconds after being read...5,4,3,2,1...Darn Chinese electronics...5,4,3,2,1...oh man, when my boss finds out I have messed up the self destruct sequence...there is a drone outside my windo
Rzrbrn is offline   Reply With Quote
Old 12-21-2018, 11:09 AM   #12
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi First325,*
We're very sorry to learn about your vents falling out. Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customer_support@airstream.com*
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Ceiling Vents Falling futzman General Repair Forum 14 10-12-2017 08:52 AM
Ceiling Air Vents Falling MeeshM 2016 - Current Flying Cloud 22 06-06-2017 10:27 AM
Changing roof vents to fan vents stgerdonly Roof Vents, Skylights & Fans 1 12-28-2014 05:42 PM
'86 Classic Cabinet door centers falling out 6inAK Cabinets, Counter Tops & Furnishings 2 09-14-2005 03:16 PM
vintage windows falling out--why? BevnCraig Windows & Screens 13 04-16-2003 06:23 AM
