Old 10-14-2012, 04:44 PM   #1
1986 25' Sovereign
Mandeville , Louisiana
'86 Sovereign Lower Window Latch won't lock
Window latch handle is jammed in the open position and will not move to lock the window when the latch arm in the locking position.
Can this be removed and repaired with lubricant or will it need to be replaced?
ASRally is offline   Reply With Quote
Old 10-14-2012, 08:52 PM   #2
1984 31' Sovereign
Edmond , Oklahoma
All I can say is, don't force it down. I broke one of them a few days ago. That little part is somewhat expensive relative to its size!
gmcryan is offline   Reply With Quote
Old 10-14-2012, 08:58 PM   #3
Remove it and soak it in WD-40 for a day or 2.
It's problem is that the shaft is corroded.
Old 10-17-2012, 06:04 PM   #4
1986 25' Sovereign
Thanks for the info gmcryan and Andy.
I'll remove it and soak it in WD-40 a day or 2 as suggested.
sovereign
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 14 09-13-2018 08:05 PM
Window and Door Gasket Kit? 1976 Sovereign gronlampa Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 08-17-2011 06:22 AM
Lower window sealing Brianv512 Windows & Screens 9 06-13-2011 06:04 PM
1975 Sovereign right front window Jim in Pima Windows, Doors, Locks & Vents 3 04-24-2011 07:51 PM
1963 Sovereign Window Frames Needed Kim-n-Mark Windows & Screens 0 03-26-2011 04:00 PM
