Old 11-13-2016, 02:50 PM   #1
Oxford , Michigan
74 Overlander wing window cleaning
Hello Everybody,
My wing windows in my 74 Overlander are wet and dirty inside and they also leak. Is it possible to remove the glass and clean the inside or do I have to replace the whole window with the frame?
Udodeschl is offline   Reply With Quote
Old 11-13-2016, 03:23 PM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Yes! It's not easy, but I did it. I have the exact same model as you. Here's the blog post for step by step.
http://thegreatleys.com/journal/2016/2/22/2-15
TheGreatleys is offline   Reply With Quote
Old 11-13-2016, 05:08 PM   #3
1972 27' Overlander
Denver , North Carolina
Or if your feeling really lucky, get a dremel tool with a glass bit and start drilling carefully. Once you puncture the window the rest will take care of itself. The inside with shatter and at that point is easily removable.
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 11-13-2016, 05:09 PM   #4
1972 27' Overlander
The above Only applies if you are looking to remove the inner pane of a dual pane Airstream Aquarium.
Old 11-14-2016, 03:45 PM   #5
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
I did this on our '74 Sovereign. I used a small cutting wheel in a Dremel to cut a slot in the interior window glass into which I planned to insert a screwdriver and pry to shatter the window. I made the cut, realized I forgot to bring out a screwdriver and headed back into the shop to get one. I was just about to enter the shop when I heard a loud crack and returned to find that the window had shattered on it's own. On the second window I wanted to see the window shatter so I made the cut and waited a minute. Nothing happened so I again headed into the shop for a screwdriver and returned to see that that window too had shattered on it's own.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper (65avion.home.blog)
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 11-14-2016, 05:54 PM   #6
Oxford , Michigan
Wing window cleaning
Thanks for the advice. It looks like I have two options. I need to think about it
Old 11-15-2016, 04:52 AM   #7
1972 27' Overlander
The window does not shatter immediately... in fact I kinda felt like Wile E Coyote, just after he runs out of road and is suspended in air... you drill the hole and you wait for three or four seconds and CRACK! The whole thing goes! BTW, the window is safety glass so it won't explode, it simply cracks and you still have to remove it.
Old 11-15-2016, 05:13 AM   #8
1964 26' Overlander
Milton , ON
A couple of people have referred to 'drilling' a hole, but I think making a slot with a little cutting wheel is better as you won't accidentally touch, and possibly damage, the exterior pane. I know from experience how easy it is to go a little too far when drilling and do some damage!
Grant Davidson
Milton, ON
1946 Spartan Manor
1964 Overlander
1974 Sovereign
TAC ON-5
Old 11-15-2016, 07:41 AM   #9
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
There is also the option of removing the window and frame assembly, removing the frame from the glass and separating the glass, cleaning and reinstalling. See this thread
http://www.airforums.com/forums/f454...ilm-37422.html
You can also use the google search for "repairing double pain wing windows" and you will get many other options.
Wing Window Interior pane removal 72 Overlander mccrosti General Interior Topics 11 03-24-2016 11:18 AM
1969 Overlander Wing Window Repair mbontempo Windows & Screens 1 09-16-2014 05:00 PM
AS Overlander 1969 Broken Wing Window Luc_DK Windows, Doors, Locks & Vents 1 07-18-2014 08:25 PM
Curbside Wing window and window by door L&R Rock Guards, Segment & Window Protectors 5 07-07-2009 10:45 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
