Old 04-18-2016, 12:14 PM   #1
1971 31' Excella 500
Altoona , Pennsylvania
Question 71 Excella 500 Window support rod removal,HELP!
Hi,I'm removing my existing windows to replace seals and tint them.Where the support rod is attached to the window frame,there is a small circular clip holding the rod in the hole.It keeps the rod from coming out of the window.I can't get it loose.Any suggestions would help.I'm keeping the original rods and don't want to screw them up,(cutting,prying,etc.).I'm sure it's simple,but I need to know what to do.Thanks and happy Airstreamin'.
dan442 is offline   Reply With Quote
Old 04-27-2016, 02:29 PM   #2
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
Could you post some pictures?
youngpeck is offline   Reply With Quote
Old 04-28-2016, 09:00 AM   #3
Window rod removal
Sorry,no pics.I figured it out though.I have a cutting wheel that fits on my drill.I placed it flush with the edge of the clip and cut through the clip enough to pry it off with a scraper.It's a very small clip,so I was careful not to cut into the window bracket.It worked well and is easy to do if you're careful.Thanks for asking about it.Dan.
Old 04-28-2016, 09:31 AM   #4
youngpeck's Avatar
1976 25' Caravanner
Good luck with your project! It always takes, and is rewarded by, creative problem-solving.
1977 Excella 500 Coastal Camper :: 1977 Airstream Excella 500 Excella77 Airstream Registry Discussions 0 08-23-2014 02:18 PM
HHOT ROD / Lightning Rod ROBERTSUNRUS Water Heaters, Filters & Pumps 4 07-11-2009 05:03 PM
Hott Rod & Lightnin' Rod femuse Water Heaters, Filters & Pumps 6 09-22-2003 11:46 AM
