Old 09-01-2014, 01:01 PM   #1
TCTradewind's Avatar
1968 24' Tradewind
Traverse City , Michigan
'68 type 3 hinge window replacement
I thought I was home free. I had replaced a bunch of windows in my 1968 Tradewind. Did the research, tempro 644 silicone caulk, hinge cleaned out really well, double sided tape on the glass. All was well for a few months. I did leave them open all summer, latched at the clips but open to air out the trailer (new purchase).
I did this back in late spring, and just this past weekend, my front glass slipped out of the hinge. Disaster averted, as it was caught oddly enough. I inspected some of the other windows I replaced, and the rear glass seems like it has slipped slightly in the hinge as well.
Is there a better adhesive I should be using to seal the window in hinge other than the tempro silicone? I could not tighten the hinge screws any further as I was having an issue with stripping on a few as it was.
I attached a couple pictures, in the event you have any tips for cleaning up the aluminum around the "airstream" lettering, I'd appreciate that too.
ID:	220477   Click image for larger version
TCTradewind is offline   Reply With Quote
Old 09-01-2014, 01:29 PM   #2
Using silicone is not the way to install your windows.
The hinge comes apart when the inside screws are removed.
Clean up the glass where you installed the silicone.
Then, install thin double sided sticky tape at the top of each glass, on both sides of the glass.
Then place the glass onto the outside part of the hinge, followed by reinstalling the inside part of the hinge.
Tighten those screws the best you can.
Let the tape alone for a day, then CAREFULLY remove any tape that sticks out from the hinge, with a razor blade.
DO NOT use any pressure when the razor blade is cutting through the tape. If you do, you could nick the glass which will make it shatter.
Why did Airstream change from front hinge doors to suicide hinge doors? arcamedies Airstream History 28 08-15-2019 12:06 AM
Type 3 Glass Bar in a Type 2 Hinge rasmuw Windows & Screens 0 12-09-2013 10:18 PM
Installing Glass in '68 type 3 hinge AudioMike Windows & Screens 6 08-22-2009 01:20 PM
1968 Type 3 window hinge not separating twisteda Windows & Screens 7 10-25-2008 09:25 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
