Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents
Old 07-29-2017, 08:14 AM   #1
kenc2131's Avatar
1967 22' Safari
Winchester , Arkansas
'67 Safari
Hi everyone, the wife and I recently purchased our first vintage airstream. We love it so much. I have a question, how do you remove the fixed windows so they can be resealed? Any and all information is greatly appreciated. Also I have discovered I'm obsessed with this trailer. Is that normal??? Lol
kenc2131 is offline   Reply With Quote
Old 07-29-2017, 10:30 AM   #2
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Fixed windows
kenc2131, I assume you are speaking about the two non-opening panes of glass below the foremost windows on the curbside and streetside windows that open. Unless you are wanting to remove the interior skins that are surrounding these two glass panes (not recommended unless interior skins are already removed for other reasons)! The easiest way to re-seal these windows is to (caulk) seal around the edges where the exterior aluminum skin meets the window frames and to also (caulk) seal where the glass and the aluminum frames meet. DO NOT USE ANY SILICONE PRODUCT ON YOUR ALUMINUM!!!! It can cause damage to the aluminum and is very hard to remove! The best product to start with in the process is called Captain Tolley's creeping crack cure. It is available at almost every Boat and marine store. When it is applied to the joint of skin to frame and frame to glass it will wick into the gap between them and you continue to apply it until it no longer wicks in. Let it cure for 24 to 48 hours and then use a product called Acryl-R to (caulk) seal around the joints you used the crack cure to seal. It is best to use masking/painters tape to place a straight line on both glass and aluminum either side of the seam. This will help you to get a nice looking seal seam. Run a bead of sealant (Acryl-R) and let it skin over then remove the tape and let it cure. It will remain flexible so don't touch it once applied. Try to use a steady hand to apply an even bead. Test it after 48 hours by running (not spraying) water over the sealed seams to check for leaks. If no leaks are found you have done it! Hope this helps, Ed
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
BIGED52 is offline   Reply With Quote
Old 07-29-2017, 03:16 PM   #3
gdanderson's Avatar
1967 22' Safari
Monona , Wisconsin
Fixed Window Interior Glazing
I also have a 67, 22-ft., Safari. One of my fixed windows leaks. I purchased from Vintage Trailer Supply, 1966-68 Airstream Fixed Window Interior Glazing, Part # VTS-504. You probably want to get the butyl rubber tape as suggested. You will not have to take the inside skins off to fix the leak.
Greg Anderson
Monona, WI
gdanderson is offline   Reply With Quote
Old 07-29-2017, 04:38 PM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
The glass is held in by the vinyl window "stop". When old (like 50 years) it gets brittle and hard. I had to replace 2 of my lower fixed windows and it was a royal pain. I would first try and reseal them. Tape off the aluminum outside and then run some tape on the glass with a very small gap. Put vulkem in the space and then press it down into the gap with a finger and then wipe off all the excess. Most of the sealer will be forced down into the gap between the glass and frame. I'm talking a tiny gap. Remove the tape immediately and then wipe any sealer off the glass with a cloth with solvent. This should stop the leak and since the sealer has been forced down into the gap you should not see any on the glass. Replacing those fixed window was one of the most frustrating and difficult task I faced. Do not drill out the rivets on the frame!!! If you do try and remove it, get new vinyl.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
68 TWind is offline   Reply With Quote
Old 08-01-2017, 12:38 PM   #5
kenc2131's Avatar
1967 22' Safari
Thanks for all the advice. I'm going to try and reseal them the way you all have said. Thanks again
22 safari sport vs. 20 safari jeffrho Member Introductions 10 01-04-2008 07:52 PM
Safari 19' vs Safari 22' michael165 2005 - 2010 Safari 15 06-04-2007 06:02 AM
On a safari for our Safari 3DogNight 2007 Safari SE 10 12-21-2006 12:54 AM
Doing research-19' Bambi-Safari OR 23' Safari-WHY? ernesto ca Member Introductions 9 04-06-2006 06:33 AM
