Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents
Old 04-23-2008, 09:36 AM   #1
SlvrSt8Steve's Avatar
Profile:  1967 17' Caravel
Reno , Nevada
'67 Front window screen frame replacement
I'm missing the screen frame for the front window on our Caravel. I've taken it around to several shops in town and nobody seems to have stock to build a new frame. Framers refer to this type of frame as flange or lip frame, due to the lip that surrounds the screen frame (see attached). Anyone know of a source for frame replacement or have an extra they would like to get rid of? Frame size is approx. 21" x 38".
1967 Caravel
2007 Toyota Tundra
SlvrSt8Steve is offline   Reply With Quote
Old 04-29-2009, 09:58 PM   #2
toddster's Avatar
Profile:  1967 20' Globetrotter
Campbell , California
SlvrSt8Steve,
Please let me know if you find a resource! My original rear window screen has been replaced with an incorrect sized lousy replacement.
toddster is offline   Reply With Quote
Old 04-30-2009, 07:23 AM   #3
Distantdrummer's Avatar
Profile:  1975 31' Sovereign
Houston , Texas
Sorry .
But the fact that several screen shops at least recognize the general shape/style of the frame material is a plus. Might mean that an exact dupe is not necessarily the only solution. If you could get the name of some of the places (distributors/wholesalers) the small shops buy their frame stock from, you might be able to start a more thorough search.
Did every window in your '67 have same screen frame?
Is it extruded aluminum? (most likely) or formed (bent from flat) ?
As for salvage from other Airstreams it would help if we knew what other mods used the same.
What other year models (besides 1967) used this exact type of screen.
Lastly and not what you want to hear, but that shape appears that it might be the easiest to faux-fab (McGiver) from common screen frame material with a flange overlaid (riveted) onto it. Like casing on a door frame or around a box frame. Using some shape of 90 degree angle. Actually the "mitered casing" would not have to be angle stock. And thin flange material aluminum is out there in numerous shapes and widths. (think flooring transitions, edge mouldings, tileboard trim, and many more).
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 04-30-2009, 07:54 AM   #4
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
Maybe your local shop could check with these folks:
Alumaroll Specialty Co. Window Screen Frame
GARY
OHIO - WE ARE THE MOTHER SHIP
Charter Member - NOVA
WBCCI - 5308
Old 04-30-2009, 12:30 PM   #5
toddster's Avatar
SlvrSt8Steve,
I found a local (San Jose, CA) company that has a near perfect match for the screen frame. The frame is a 5/16" aluminum lip frame. For $9.00 I got 12ft of the frame and 4 internal corner connectors - enough to do the front or rear window with a little wiggle room. Their contact info is:
thescreenshop
Old 05-07-2009, 10:15 AM   #6
flyrc's Avatar
Profile:  1956 22' Flying Cloud
1956 26' Cruiser Overlander
Yakima , Washington
I have three screens for the 66/67/68 model Airstream's. They are for the 29" side windows and the 17" front door window.If anybody need these, please send me a PM.
Last edited by flyfshr; 05-07-2009 at 03:32 PM. Reason: Personal phone number deleted - use PM instead.
flyrc is offline   Reply With Quote
Old 05-13-2009, 01:32 AM   #7
Profile:  1968 24' Tradewind
dixon , California
I have 68 and could buy these from you..
I would buy these from you,...my name is colleen at jesuslives63@sbcglobal.net..thanks..
colly1 is offline   Reply With Quote
[IMG] code is Off
replacement part for a window frame? zoeb nj Windows & Screens 2 01-09-2008 12:23 PM
Window Frame Replacement dlx25225 Windows & Screens 5 04-18-2007 06:35 PM
Looking for front window frame-63 Globe Trotter my63gt Windows & Screens 3 07-12-2005 08:52 PM
Window screen replacement smallfry Windows & Screens 15 04-30-2004 03:15 PM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 06:03 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
