Old 04-23-2015, 10:26 AM   #1
1968 24' Tradewind
Oakland , California
Exclamation 6' x 3' Serving Window
Hello Everyone,
I am a metal fabricator in California, typically I do architectural work but I've taken on a job modifying a 68' Trade Wind. The client would like to make the two center windows on the drivers side into a 72" x 36" serving window for his ice cream business. I could use some tips on how to do this right, I have learned a lot looking around on this amazing forum, I'll be sure to post some progress shots and share what I learn along the way.
The attached photo shows the area I'd like to modify lined in blue tape. This process would remove two of the u channel studs, I plane on cutting it back to the studs closest to where we want it and first framing the opening in 6063 AL.
From here I'd build the fixed window frame, and then fabricate the window.
Am I on the right path? Does the frame need further re-enforcement? Any tips much appreciated.
Thanks!
Sam
ATsamD is offline   Reply With Quote
Old 08-10-2019, 09:09 PM   #2
1965 22' Safari
Dalton , Georgia
Hey Sam,
Did you ever complete this project? Any detailed pics of how you went about it?
LoneWolf2 is offline   Reply With Quote
Window Replacement New Window Gaskets pawnguy Windows & Screens 12 09-05-2017 10:17 AM
Only one out of 4 outlets is serving power kayt Electrical - Systems, Generators, Batteries & Solar 7 09-23-2013 03:12 PM
Curbside Wing window and window by door L&R Rock Guards, Segment & Window Protectors 5 07-07-2009 10:45 PM
Window Latch Assembly (window locks) Sue&Von Windows & Screens 17 02-10-2009 06:32 PM
Replacing Nylon Window Guides - not holding window up Tom Bray Windows & Screens 5 06-16-2008 06:52 AM
