Old 03-21-2016, 06:43 PM   #1
Surf City , New Jersey
19 ft bamb rear escape window
Does anyone know if the rear escape window opens for venting?
It looks like the others that are on the curb side but lacks the two levers that push it out.
It only has an emergency pull loop.
Im thinking it must open otherwise there is no use for the screen
weber.roger is offline   Reply With Quote
Old 03-21-2016, 07:16 PM   #2
2012 20' Flying Cloud
Bishop , California
My window is the same in the 20 ft. model. Apparently Airstream was to cheap to put in a lever to hold open the window. I made "window prop" from a piece of 1x2 wood to hold the window open for better ventilation on warm days.
Bill
billdunlap is offline   Reply With Quote
Old 03-21-2016, 09:00 PM   #3
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Yup, me too, more fresh air the better.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 03-21-2016, 09:11 PM   #4
2005 19' Safari
GLENDALE , AZ
Not sure about newer models, but if the back window on our 2005 19' Bambi is opened far enough, it can fall off. The hinge is not "captive", and the window is designed to be pushed out completely for emergency evacuation. Consequently, for ventilation purposes, use caution to avoid window falling out and breaking.
I could be wrong; but I suspect the window is only available from Airstream, and a replacement probably isn't cheap.
Old 03-22-2016, 07:00 AM   #5
how far out will you push it? Will it fall off the hinge?
Old 03-22-2016, 07:43 AM   #6
Bill
How far can you open it?
Old 03-22-2016, 08:02 AM   #7
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
My 25 EB has operators, as did my 06 Safari, and works like normal. Doesn't surprise me that they went cheap on the little ones, though. LOOK at the hinges on the other windows and at what's holding your emergency window in place. If they're different, I'd proceed with much caution. I'd order the operators and hinges from either Out of Doors Mart or Colonial Airstream to upgrade it. Those are two dealers who'd know enough to tell you what's involved.
BTW - windows - The Base model Flying Cloud (nee Safari) versus the SE versions of the same - have different windows. The base has a Herr window. Solid top, slider about six inches high across the bottom. The frames are black neophrene.
The SE and of course the classic have one piece curved glass windows with a top hinge that allows the window to be opened fully - and the frame is riveted aluminum. And THOSE are the expensive ones. Herr's are generic and many non-Airstream RV's have them.
Paula
Foiled Again is online now   Reply With Quote
Old 03-22-2016, 10:45 AM   #8
50KIP's Avatar
2009 19' International
Woodinville , Washington
My 2009 19' has the same window. I ordered one operator (left) from the dealer. Cut off the part that goes to interior. Of course I have to go outside to open window but it works well to vent rear of trailer.
50KIP is offline   Reply With Quote
Old 03-22-2016, 12:58 PM   #9
2016 30' Classic
Santa Rosa , California
I made the mistake of opening my FC20's emergency window too far and it fell to the ground and shattered. $400 lesson. I mistakenly thought it was hinged from the top - ie that you could open the window and LIFT it off the hinge. That is not the case. It hinges from the underside and drops off all by itself once the window is opened far enough. Once replaced, I never opened it again.
phann is offline   Reply With Quote
Old 03-22-2016, 01:35 PM   #10
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
On my 2016 FC 20, there are arms to hold the window open. I think this is the first year AS put them in on the rear window.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
WTB: rear escape window Reuben Byrd Airstream Classifieds 0 03-17-2014 02:14 PM
1966 Avion T27 rear window - "escape"? 7GenTex Vintage Kin 2 02-14-2014 05:32 PM
'99 Rear escape window leaking outbackbob 1999 Safari 18 06-08-2013 07:04 AM
Rear Escape Window Seal outbackbob 1999 Safari 0 12-23-2012 08:28 AM
Escape window function mojo Windows & Screens 22 01-24-2010 05:27 PM
