I don't do it that way. I disconnect the line before the pump and attach the hose to the pump then put the other end of the hose in the gallon jug.
It wouldn't hurt anything doing it the way you say you'd like to, it's up to you. Some will say NO NO, some will say OK OK, it's your belly the water from the freshwater tank will be going in to if you drink from it.
Question is, I guess, will the flushing process in the spring clean out the freshwater tank to your satisfaction?
