09-19-2017, 09:32 AM
2018 30' Flying Cloud
Edgewater Park
, New Jersey
Winterizing
Do most of you use the 'pink' or do you just blow out all the water with an air compressor?
09-19-2017, 10:17 AM
2015 30' Classic
Glen Mills
, Pennsylvania
Pink. Installed a valve @ pump, attach suction tubing place in jug and done.
09-19-2017, 10:21 AM
1993 34' Excella
Estancia
, New Mexico
Some do both. Don't forget to drain your hot water heater and bypass if you have one.
09-19-2017, 10:29 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Pink or Blow
I pinked & blew for 25yrs....blow only for the last 5yrs, pink in the traps with the pump drained.
But....it's much easier with a large dual stage compressor.
I use a regulated line at a constant 35psi pressure with at least one line open, at least 15min for each line, NEVER above 45psi.
Bye-pass for the water heater, drained & blown out.
"You don't know where you've been until you leave, enjoy life" RLC
09-19-2017, 11:06 AM
Traveler
2017 25' International
Staunton
, Virginia
This is how I winterize.
09-19-2017, 11:08 AM
Opinionated newb...
2018 25' Flying Cloud
League City
, TX
A wonderful solution that....
Men are but men, and the greatest men are they who soonest learn the simpler things. ROBERT E. HOWARD
What a man does for pay is of little significance. What he is, as a sensitive instrument responsive to the world's beauty, is everything! H. P. Lovecraft
09-19-2017, 11:11 AM
Len and Jeanne
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley
, British Columbia
We normally do both. Better safe than sorry, although it does take a while to get the anti-freeze out of the system after de-winterizing.
09-19-2017, 11:28 AM
2014 25' FB Flying Cloud
Des Peres
, Missouri
Do you connect your air at the city water connection?
I can't quite tell from the pictures
09-19-2017, 11:30 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Prior to our 2017 Classic with the Alde system we only blew out our lines with the previous 13 RVs, which included 3 other AS trailers. Now, with the 2017 Classic and Alde system we blow it out and add RV Anti-freeze. For some reason I cannot get all the water out of the system simply by compressor and I don't want to go above 60# pressure.
Bud
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
09-19-2017, 03:38 PM
1995 25' Excella
xxxxx
, xxxxxx
Both
09-19-2017, 03:55 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Pink stuff in the waste tanks and macerator pump. Air only in the freshwater system.
Side note, an Airstream Interstate has Hepvo check valves in place of p-traps, and so doesn't need pink stuff in the drains.
09-19-2017, 04:21 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Yes..at the city water connection, and the pressure relief valve on the water heater, with the drain petcock open.
09-19-2017, 07:01 PM
Edgewater Park
, New Jersey
Originally Posted by TravlinMan
I think you win the prize!! LOL
09-19-2017, 10:57 PM
2022 25' Flying Cloud
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden
Pink only. Never have used air.
2022 25RBT FC, 50A Dual AC, Awning Package, 270W Solar, Convection Microwave. Ceramic Coat, Grand Lounge, 3" Lift, 16" Michelin RIBs, Multiplus II, Battleborn 400A, MPPT 100/50, Orion-TR 30, EasyStart (2), Easy Touch, AirKrafters jenRack, Onan 2500i, Truma Aquago Confort, Starlink, Pepwave, Parsec
09-20-2017, 07:13 AM
2017 23' Flying Cloud
Parker
For those that use pink only, even in the fresh water system, how do you specifically flush the system out to get that taste out?
Troutboy
09-20-2017, 07:18 AM
2017 25' Flying Cloud
Fayetteville
, Arkansas
I drain the pink anti-freeze, fill the system with fresh water and bleach as required to sanitize the system, and then flush the system as required by the sanitation. No more pink stuff or taste.
FishByFly
because I catch fish on a fly...
2017 25' Safari FBQ - “Fly Fish Inn”
2023 F150 XLT
09-20-2017, 08:55 AM
High Point
, North Carolina
My AS is new, this will be my 1st winter with it, I live in NC so temps rarely go below 20F. Question, if I've never used my fresh water tank & pump, only city water, do I still need to drain and/or winterize the pump?
09-20-2017, 09:12 AM
2004 30' Classic Slideout
Fenton
, Missouri
My dealership used air pressure only. He noted that he opens all outlets on the trailer and uses high pressure and finally provides at least a half hour or more of blow time. He says that insures the lines are dry.
From my standpoint I blow the lines out and then run RV antifreeze into the lines via the water pump tied into a hose into the antifreeze bottle.
Also I use a name brand antifreeze. I never was picky until I had a bottle of no name stuff, soften and melt down the flush bladder that was in the toilet flushing system in my SOB’s toilet. Since then I have stuck with the Prestone branded RV antifreeze. Twice the cost of the no names but I can be assured of the quality.
Jack Canavera
STL Mo.
AIR #56 S/OS#15
09-20-2017, 10:42 AM
Sag Harbor
, New York
Yes that would be a good idea to do a full winterization, so as to cover all the variables. Draining the tank, and taking the pump apart to check the filter is a good annual practice anyway.
One little detail we take the time to do, after the pump and filter are disassembled, is to blow [using your mouth] into the water line coming from the water tank. In some AS models, there is a hidden low point in that line which can trap water which will freeze. Only takes 5 seconds to do this. With the tank's drain valve open, and raising and lowering the tongue to drain water from the tank, you are covered for all eventualities.
"Measure once, cut twice" as we say in construction!
Good luck,
Peter
PS -- We never use antifreeze as blowing out the lines with air does a fine job, and you don't have to deal with the AF odor/chemical risks next Spring.
09-20-2017, 11:24 AM
High Point
, North Carolina
Thanks! I agree...better to be safe than lazy & then sorry!
