Join Airstream Forums Today
Old 09-28-2011, 11:24 AM   #1
Alumaholic's Avatar
Albuquerque , New Mexico
Why Two Petcocks?
Why do I have two petcocks drains on my freshwater, holding tank?
Ken
2007Chevy 2500 HD Duramax/Allison
NM Unit WBCCI #8654, Affiliate Four Corners Unit
"Those Airstream photos on the internet that fuel your fantasies will always capture the gleam of aluminum, but rarely all the blemishes, and never the smell."
Alumaholic is offline   Reply With Quote
Old 09-28-2011, 11:32 AM   #2
clancy_boy's Avatar
2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Hot water side - Cold water side of the plumbing system. Big tank drain should also be there - maybe looks like aone bug nut you take off with a wrench.
Michael, Tina & Layla BZ
1966 17' CARAVEL LUCY
2003 22' INTERNATIONAL CCD DESI
Old 09-28-2011, 01:29 PM   #3
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
I think my trailer may be similar to yours. I have 2 brass petcocks that look similar to the drain on a car radiator. These are the low point drains for the hot and cold water lines on the street side. Close by is a white plastic (nylon?) spigot. The handle on it will pivot 180 degrees but as I recall is only open in the 90 degree position. This is the fresh water tank drain valve. On mine there is also a 4th valve near the 3 water heater bypass valves and looks just like them. This is the low point drain for the curbside of the trailer.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 09-28-2011, 01:37 PM   #4
clancy_boy's Avatar
1966 17' Caravel
Kiln , Mississippi
Images: 8
Wow, I have to quote myself here to explain. I ment to say "one big nut" not "aone bug nut" - actually, mine has a 4 sided brass threaded plumbing plug in my tank drain location. The PVC and valve hung too low and rubbed once getting into a parking space. It was at the center pivit point of my trailer. I was told by a dealer the PVC valve was an owner add on - not from AS - but I have seen them on several trailers like mine.
Old 09-28-2011, 01:38 PM   #5
Alumaholic's Avatar
Hmmm. Must Find White Valve
By golly, Yank, I believe you are correctomundo.
I now recall, that is how my 2000 was configured.
Now, I just have to find the white, plastic spigot.
Ken
Old 09-28-2011, 02:39 PM   #6
2008 27' Classic FB
Burkburnett , Texas
Pics are my favorite. The low point drains look like they are coming out the bottom of the FW tank and is easy to understand why you thought that. On mine, the FW drain is one the side dead center between the tires. As Clancy suggested, you may have a simple plug instead of a spigot. See if you can find the other low point drain I mentioned above. It would be easy to overlook if you didn't know it was there. In this photo it is the one one the bottom right.
ID:	141202   Click image for larger version
AIR 47751
Old 01-15-2012, 05:38 PM   #7
benjisgal's Avatar
2010 23' FB Flying Cloud
Fayetteville , Georgia
Images: 13
My petcock broke off during my trip to Alaska. I don't know whether it's all the rocks that I drove over or from a piece of re-tread that I hit on my way out of Atlanta. In any event, the guys in the Jayco caravan plugged it for me and it held pretty well. My Airstream is now at Jackson Center being repaired for some exterior damage and some warranty issues. Three months on the road and I am well-versed on my Airstream. Those weekend trips just didn't do it.
Benjisgal
WBCCI #1122
Top of Georgia Unit #52
“I don’t want to get to the end of my life and find that I lived just the length of it; I want to have lived the width of it as well.”
---Diane Ackerman (Author, poet, essayist, naturalist)
benjisgal is offline   Reply With Quote
