Old 09-11-2008, 01:19 PM   #1
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Why shouldn't I do this with the plumbing.???
Ok, Putting in the new water tank this week,, The plumbing to the hold one is a mess... I would like to simplify it.. As you can see in the picture it is a hobcobble of stuff...
It has a valve of the main line directly into the water tank... I'm guessing this was used to fill the water tank while connected to shore water... I would like to get rid of this as I have the big cap on the outside and it will fill faster there...
Is there a reason I shouldn't do this???????
There are also 2 drawings: one of the old because it's hard to see in the photo, and one of what I would like to have... Yes I will be putting a filter in the line just didn't draw it in...
I figure less connections, means less chance of a leak...
And I am putting in a newer pump, the old one has a belt and baffle .. Makes a little noise
ID:	67216   Click image for larger version
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-11-2008, 01:23 PM   #2
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Jason- I agree with you 100%! I did exactly what you are thinking in our Tradewind. Works just fine, remember tio have a vent line/overflow coming out of the top of the tank.
Rick
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 09-11-2008, 02:24 PM   #3
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Did the same thing to the GT. There was also enough room to add a good sized Culligan RV under sink filter. It's tight but I can still access the drain valve and drain/clean the filter when winterizing.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 09-11-2008, 02:36 PM   #4
purman's Avatar
1968 28' Ambassador
Thats a good idea It think I will have enough room for this... I have a pre filter in before the pump too...
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-11-2008, 06:26 PM   #5
till's Avatar
Lisle , Illinois
Images: 108
You are correct on your thoughts of what the "extra plumbing" is for. I use it all the time. It is a matter of what you want to go. I plan on re-installing it in my trailer.
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 09-11-2008, 11:07 PM   #6
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
There should be a check valve to prevent city water from ever reaching the tank except through the outdoor inlet - folks have had their floors pulled off frame from ballooning water tanks. A strainer is mandatory before the pump to keep grit from cutting seals up; a point of use filter for drinking water and cooking is probably a better bet over the long term yet a whole system UV sterilizer is money well spent when you are filling from unknown sources to keep chlorine etc use to a minimum...
Old 09-12-2008, 08:26 AM   #7
purman's Avatar
1968 28' Ambassador
Doesn't the pump have a check valve built into them???
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-12-2008, 09:22 AM   #8
Some pumps do, and some pumps don't.
Those that do, seldom hold up to city pressure for days on end.
Then they leak, overfill the water tank, and depending on the tank and location, can simply spill out on the ground, or floor, or fracture the tank.
Old 09-12-2008, 11:21 AM   #9
dnrtheil's Avatar
1964 24' Tradewind
Portage , Michigan
Purman, that's how I have mine hooked up. I have a Shurflow pump, do not remember the model off hand, it does not let city water fill the tank. Vent/overfill is a good idea. Good Luck.
D
Operation "SAVE RUDY" Strike Team (Associate Member)
dnrtheil is offline   Reply With Quote
Old 09-12-2008, 01:42 PM   #10
purman's Avatar
1968 28' Ambassador
Not going to be hooked up to water to often, but I guess it my be worth the money on a little stop tap after the pump for those extended stays at an RV park???
I have a new Shurflo modle 2088-492-444. Man even if I put in a stop valve I will probably forget to shut it.... It says it has a Check valve built in... I guess I will put one in, good practice with my copper pipe skills...
OOO man, I just made the mistake of blowing and then sucking on the pump.. Got some YUKY tasting water in my mouth..
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
plumbing help HDS Fresh Water Systems 1 07-06-2006 02:59 PM
Help With Plumbing carnegie1935 Plumbing - Systems & Fixtures 3 06-21-2006 10:22 AM
Plumbing my A/S blucloud Fresh Water Systems 4 06-11-2004 06:16 PM
Plumbing jack simons Fresh Water Systems 1 10-21-2003 03:50 PM
Need new plumbing? wardster All Argosy Trailers 5 08-17-2003 10:08 AM
