Old 04-02-2015, 11:39 PM   #1
1982 28' Airstream 280
Epps , Louisiana
Which adhesive to use on septic connections
I am replacing a busted Thetfort valve on my 1982 280' motorhome. I was able to disassemble the original connections by applying heat from a heat gun and I have all the replacement parts. I need to know what adhesive to use to reconnect the septic drain pipe connections. I have seen posts that mentioned theTremco brand but they didn't mention the specific product. I want something that will seal the joints but can also be removed with heat like the factory adhesive.
Thanks ahead for any suggestions!
general78
general78 is offline   Reply With Quote
Insulation in the walls -- adhesive or no adhesive? wrajr Repairing/Replacing Floor &/or Frame 8 04-27-2010 09:08 PM
Which flooring adhesive? Anniedog Floor Finishes 1 09-18-2009 05:23 AM
Use of Construction Adhesive - Any Thoughts? Gael79 Cabinets, Counter Tops & Furnishings 4 05-19-2008 04:19 AM
Sewer connections - what do you use or recommend? kudzu Community Polls 13 06-11-2006 08:10 PM
Black water tank with septic system rfield54 Waste Systems, Tanks & Totes 3 09-26-2003 06:31 PM
