Old 10-28-2014, 11:50 AM   #1
grayling's Avatar
1961 16' Bambi
Avinger , Texas
Where does YOUR slinky live?
Vintage trailer people - where do you store your slinky when not in use? Did you have to build a compartment? Pics would be great!
I have no slinky shack on my trailer. Guess I will have to construct one, maybe paint a large PVC pipe with aluminum paint and strap it under the bumper?
grayling is offline   Reply With Quote
Old 10-28-2014, 11:55 AM   #2
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
Our first trailer didn't have a storage spot for the slinky. My husband did what you are thinking about. He took a large PVC pipe, painted it black and used screw off fittings on it. He then used some sort of metal strapping to attach it to the underbelly.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 10-28-2014, 12:23 PM   #3
Gainesville , Florida
Slinky storage tubes are available in different lengths at camping stores. I painted mine and slid it crosswise behind my lp tanks. Jim
Old 10-28-2014, 12:34 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
You don't need a slinky if you use a "Sewer Solution" brand sewer drainage system, it only uses a 10' - 3/4" hose (another 10' extensive can be added when needed) which is rinsed well with each use without the mess.
We been using the same one for five years without problems.
Doug and Cheryl
Old 10-28-2014, 12:36 PM   #5
oh2bcarefree's Avatar
House Springs , Missouri
Images: 48
We put the slinky in a rubbermaid tub with lid that goes in the truck bed.
Tina
Tina and Mike
1959 Avion e-20
oh2bcarefree is offline   Reply With Quote
Old 10-28-2014, 01:45 PM   #6
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Don't you need epic amounts of water for the Sewer Solution?
I used one once and was left with a giant mess left in my tank! Never again!
We have 2 under belly mounted tubes with caps on both ends.
Old 10-28-2014, 02:23 PM   #7
2000 30' Excella
Monticello , Florida
6 yrs with a sewer solution and no problem... back flushing help clean out anything left in the tank.
07007 is offline   Reply With Quote
Old 10-28-2014, 02:26 PM   #8
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
You can actually drain quite effectively with little or no water. Just break up any obstructions or chunks, and backflush only after the tank is drained - then you'll "produce" the rest of the waste.
Using the little pressure mascerator thingy requires a regular stream of water only if you are flushing uphill. Then you point it down the hose and it creates enough pressure to suck the "stuff" out of the tank.
I fulltime, so I don't ever need a pristine tank - or at least won't have one for more than a few hours/beers. If I were planning to store the Silver Suppository unused for any length of time, I'd use the built-in tank rinsers for a prolonged period, then dump a couple of waste baskets full of water down the throne to really "float the Titanic".
Oh and a great place to store a Sewer Solution is in the duty drywall bucket with some soapy water. Drive 50 miles and it'll be clean as a whistle inside and out. I'm often camping on dirt, and the SS doesn't need a little ramp thingy so it sits on the dirt - after a week earthworms and snails are inhabiting the area when I pick it up.
Paula
Old 10-28-2014, 02:34 PM   #9
Goal15's Avatar
Dallas , Texas
Tina
Same here.... but I'm wondering if I don't need to disinfect the inside of the tub on occasion....
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 10-28-2014, 02:34 PM   #10
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Sewer Solution - 5 gallon bucket, cap full of bleach and a bit of water during transport. Cleans it right up.
Slinky - use the light weight but strong tube with caps available from Camping World. Cost efficient and ready made for installation.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 10-28-2014, 02:38 PM   #11
dkottum's Avatar
Epic amounts of water is available if needed at most RV dumps, but you actually may need little to none, as Paula described above. In five years (2 1/2 years total full time) we have not had a mess left in the tank.
Doug and Cheryl
Old 10-28-2014, 02:43 PM   #12
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
I guess I need to give mine another chance. I flushed for 30 minutes until it came clear. During the next week I looked down the hole to see the slurry of what was left behind, it was not pretty. I have had great luck with the 4" hose letting it rip! I can always see the white plastic of the tank... Rarely do I even flush! There is a YouTube video I'll have to post showing the effacacy of three dump methods, the sewer solution was at the very bottom of the list, the tornado type tinder was by far the cleanest winner!
No offense to the ss users!
Old 10-28-2014, 02:49 PM   #13
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Here is the video link...
http://youtu.be/dfTd0Slt_cU
Old 10-28-2014, 03:32 PM   #14
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
A previous owner of my AS built a box that goes under the A-frame/tongue. Whoever made it did a really good job. Initially I thought it was from the factory, but after learning more, that's unlikely. I'll try to attach pictures.
Thalweg is offline   Reply With Quote
Sewer Solution or 'Stinky Slinky' kswelsh On The Road... 38 03-28-2014 08:03 PM
Solution for 'slinky' problems Chipster Waste Systems, Tanks & Totes 47 10-03-2013 08:29 PM
Stinky Slinky Storage BAB Waste Systems, Tanks & Totes 1 06-19-2013 08:02 PM
Plumbing for "Stinky Slinky" barts Waste Systems, Tanks & Totes 0 09-12-2011 08:03 PM
Slinky Storage Jabba Waste Systems, Tanks & Totes 6 01-29-2003 10:31 PM
