Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 03-07-2003, 04:51 PM   #1
Question where are water drain valves/1990 Excella 32' ?
After reading the manual for our new 1990 Excella 32', we have located the water drain valve under the bed.
The 3 other ones are supposed to be in the false bottom of the cabinet under the microwave. NO
On other lengths for that year, they say they are under the sink.
We will eventually find them, but we don't mind saving some time.
Before we take apart the bottom of the cabinet for nothing, we should ask if anybody knows where these 3 valves are located.
Thank you.
Chantal & Mike
femuse is offline   Reply With Quote
Old 04-27-2003, 05:07 PM   #2
Update:
we have found 3 valves:
the one under the bed, and 2 under the sink.
My question now is:
do we have 3 valves or 4 valves ?
if we have 4: were the h@*#$ is this 4th valve?????
Thank you.
Old 04-28-2003, 01:47 AM   #3
Have you looked inside the rear underbody locker by the city water intake? Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 04-28-2003, 09:13 AM   #4
Yes, we have, thanks
that's the one under the bed.
Old 02-10-2023, 03:20 PM   #5
'90 Excella 25C
1990 25' Excella
Wells , Maine
I'm a bit late for this post but for the record
Don't forget the tank drain, outside, behind the curb side rear tire.
jerunamuck is offline   Reply With Quote
Old 02-10-2023, 03:34 PM   #6
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Crawl under your trailer and look for the 1/2" diameter tubing sticking out from the belly pan. That will tell you where to start looking for the drain valves.
We have a 1994 Excella 25-ft, and we have two low-point drains under the sink, a water heater drain at the water heater, and a tank drain. You'll likely have at least as many but the locations will likely be different. Find the drain tubes and you'll be on your way.
Richard
11018
richard5933 is offline   Reply With Quote
White water tank drain ramoore53 Fresh Water Systems 5 02-19-2024 04:08 AM
water drain valve leaking - help! wayner1239 Fresh Water Systems 14 02-01-2004 04:10 PM
water drain valve leaking - help! wayner1239 Waste Systems, Tanks & Totes 0 01-31-2004 10:03 AM
How cold for winterizing? ipso_facto Our Community 27 12-03-2003 04:56 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
