Old 10-16-2019, 12:09 PM   #1
Riverview , Florida
What is this drain? Help
Hello! We have a 2019 flying cloud bunk I recently notice when we will fill up the toilet with water. This drain will flow water outside? Would like some help why this is happening. Or how to stop it. This is not the ac, or fridge lines. Itís located right under the bathroom.
Squirestrhn is offline   Reply With Quote
Old 10-16-2019, 12:15 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Is it your water heater drain? Look for a handle along the water pipe that is going perpendicular to the pipe - that tells you itís open. Twist it to the right so itís in line with the pipe and it should stop. Also - fill the water heater with water before you turn it on.
If thatís not it - hopefully a smarter person will chime in
SteveSueMac is online now   Reply With Quote
Old 10-16-2019, 02:21 PM   #3
Riverview , Florida
The drain comes straight out the floor. The water hearted is on the other side of the Coach
Old 10-16-2019, 02:57 PM   #4
Long Island , New York
Does your owner's manual cover this?
Look inside the bath, above the drain pipe you show, and see if you can find a low-point drain which only has water in it when you flush. I seem to recall a thread where there was such a thing. [edit -- see below]
What length is your bunk unit? You could add this info under your user name via the User Control Panel linked at top left.
Is your FC bunk a 30' ?
See here: http://www.airforums.com/forums/f163...et-183480.html
Post #4 there:
[click on orange arrow in quote to go directly to the post]
Originally Posted by OTRA15 View Post
Hi Jason,
I was referring not to a video but to this photo in the post I quoted:
Is this what your setup looks like? If so, I think that one side of that white valve leads to the white tube that is dripping under your trailer [which makes this entire set up a low-point drain].
Also I did not mention any "flush out" per se, so maybe we are talking about different situations? If your setup is like the above, I would try toilet operations with the valve open and closed, to see what happens outside, as observed by a second pair of eyes.
Also, do you have a macerator toilet? That seems to be one of the variables in that other thread.
Anyway, I think I will bow out here -- I just wanted to make sure you had seen that other thread.
Good luck!
Peter
Good luck,
Peter
[ S. P. ]
PS -- 30' yes:
Originally Posted by Squirestrhn View Post
Hey y’all!
We are picking up our 30fb bunk next week.
OTRA15 is online now   Reply With Quote
Old 10-16-2019, 03:34 PM   #5
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Air conditioner condensate drain
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 10-16-2019, 03:43 PM   #6
PS -- missed the edit time window -- See also this 2015 Post #180 in a Bunkhouse thread:
[click on orange arrow in quote to go to that thread]
Originally Posted by PharmGeek View Post
I would bet a few bucks that low point drain is open
Go outside behind the wheels just ahead if the dump valves - there will be a small PVC tube pointing staight down - have someone inside hold the flush button and watch water come out - if it does that's your problem -
The dealers winterize and leave it open - finding that valve is a trick - must find water pump - it's near it
Ken, the OP says not the A/C drain.
Peter
PS2 -- A direct link to another thread FYI, Squirestrhn:
http://www.airforums.com/forums/f542...et-155658.html
Do you have a macerator toilet BTW?
Old 10-16-2019, 03:48 PM   #7
Alumaholic's Avatar
Images: 36
Oops. Sorry!
Peter
Right you are.
Ken L
Old 10-16-2019, 06:40 PM   #8
Riverview , Florida
Itís not. Thatís located under the tire. This one poors water out only when we fill the toilet
Old 10-16-2019, 06:45 PM   #9
Riverview , Florida
Heres a link to the video
https://youtu.be/PLIP2kcrUeY
Old 10-16-2019, 07:30 PM   #10
No one is questioning the water pouring out of that tube, although the sound in the video does confirm that you are flushing the toilet!
Have you checked the threads/posts linked in Posts #4 and #6? Your answer is there IMO.
Peter
Old 10-17-2019, 11:23 AM   #11
ft. myers , Florida
It is from your AC unit.
fladealer is offline   Reply With Quote
Old 10-17-2019, 12:09 PM   #12
Not the A/C per OP.
Hello! We have a 2019 flying cloud bunk I recently notice when we will fill up the toilet with water. This drain will flow water outside? Would like some help why this is happening. Or how to stop it. This is not the ac, or fridge lines. It’s located right under the bathroom.
Old 10-17-2019, 02:16 PM   #13
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Does you toilet have hand held spray line with it? Looks to me like somebody routed the spray line outside instead of installing the spray or plugging off the line for it.
Old 10-17-2019, 02:22 PM   #14
Getting warmer . . . see Posts #4 and #6.
Peter
Old 10-17-2019, 06:40 PM   #15
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
My hot water heater had a pressure valve (not the exterior valve) that was located on some piping that came off a one way interior check valve located on the inside wall of the water heater. The check valve was faulty so the dealer removed the check calve and replumbed the hwh, adding a new pressure relief line and valve. This valve was also faulty and under pressure stuck in the open position so that it discharged out of a similar pipe in the same location as yours. Since mine was a custom repair with similar results that you are showing, I doubt that is the exact same issue. However, there may be a faulty pressure discharge valve in your system, creating the same problem. Good luck.
Jim Flower is offline   Reply With Quote
Old 10-18-2019, 10:36 AM   #16
See Posts #4 and #6. The "low-point drain" location answer is there.
Peter
Old 10-18-2019, 10:37 AM   #17
Have you found that hidden low-point drain?
Peter
Old 10-19-2019, 01:55 AM   #18
Spartanguy's Avatar
Louisville , Alabama
All Flying Cloud bunks are 30ís and all bunks are Flying Clouds...or something like that . The 30 bunk was my original choice, always had this idea of turning the back room into a study/recliner area then learned the water heater or is it the furnace? is back there. One of my favorite models. Colonial has a video from 2015 that made me fall in love with the 30 bunk. I have an unidentifiable drain hose coming out of my 25FC near the water heater, a water heater drain is my guess.
Spartanguy is offline   Reply With Quote
Old 10-25-2019, 12:38 PM   #19
Wondering if you found that drain, so that other Bunk owners can learn from this.
Peter
Re working kitchen drain- pex for drain lines?? bwilson1 General Repair Forum 4 04-20-2014 09:42 PM
fresh water drain: broke it off. help jpar Fresh Water Systems 12 10-07-2009 07:20 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 05:09 PM
water drain valve leaking - help! wayner1239 Fresh Water Systems 14 02-01-2004 05:10 PM
water drain valve leaking - help! wayner1239 Waste Systems, Tanks & Totes 0 01-31-2004 11:03 AM
