Old 02-25-2006, 01:01 PM   #1
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
What is this dohicky?
So here is the deal: under my gaucho near the pump is this clear dohicky in the waterline. Is this a filter or trap for sediment? It looks like it has a fair amount of gravely looking stuff in it. Should I take it apart in clean it? Replace it? or just pretend I never saw it before?
Name:	plumbing dohicky.jpg
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 02-25-2006, 01:04 PM   #2
bill benton's Avatar
Mansfield , Texas
Looks like a filter to me. But it looks more like a sediment strainer of some kind.
bill benton is offline   Reply With Quote
Old 02-25-2006, 02:02 PM   #3
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
Sure, that's the fuel filter from my lawn tractor.
Really, it looks like a sediment filter. Is that the water pump in the foreground?
Dennis
cosmotini is offline   Reply With Quote
Old 02-25-2006, 02:35 PM   #4
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Yes it is
Rodney
and the
My Blog
Old 02-25-2006, 06:34 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
Usually a strainer to pre-filter your water before entering the pump to prevent clogging or pump damage.
Old 02-25-2006, 06:44 PM   #6
eubank's Avatar
1967 30' Sovereign
Bosque Farms , New Mexico
Yep, ours has the identical doodad. I think it's a sediment filter.
By the way, our original pump -- just like the one in the edge of your picture -- started leaking, so I had to put in one of the modern ones. Totally without the panache of the original, even if it is out of sight! (I kept the original with the idea that someday I might be able to seal up the leak and put it back into service.)
WBCCI 21043
eubank is online now   Reply With Quote
Old 02-25-2006, 06:51 PM   #7
Tin Can's Avatar
2005 31' Classic
wilson , New York
Images: 8
Rodney,
It it a filter of some type. If you can take it apart and clean it then that would be the thing to do. If , on the other hand, it is a sealed unit then replacement would be the only option. An old trick by manufacturers to get your money. Hope this helps.
Tin Can
"Your edumacation ain't no hipper than what you understand"- Dr. John
'05 Dodge 2500 SLT 4X4
TAC# NY-5256
Tin Can is offline   Reply With Quote
Old 02-27-2006, 03:47 PM   #8
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Mine leaked and I took it apart under the guise that it wasn't gonna hurt anything. It already leaks. Found a "O" ring and replaced it. Doesn't leak now. and still pumps water.
>>>>>>>>>>>>>>>>>>>>>Action
Old 02-27-2006, 04:42 PM   #9
eubank's Avatar
1967 30' Sovereign
Originally Posted by Action
Mine leaked and I took it apart under the guise that it wasn't gonna hurt anything. It already leaks. Found a "O" ring and replaced it. Doesn't leak now. and still pumps water.Action
Ah, good tip! I'll check that out when I get that far! Unfortunatly, I get the feeling that one of the inlet pipes cracked; it happened at the same time that the main water line under the couch cracked as well. Ugh!
Lynn
WBCCI 21043
Old 02-28-2006, 01:02 AM   #10
_
hi gen disarray and others.....
sure ignore it, that's always the first option....surely it was a pre/sediment filter for the pump....but now that it's full of gravel....it's become a gizard for your trailer....muching the solids so you don't have to chew your water....
prompted me to look for a pic of mine...left upper corner.
airstreams never change....except for owners.
cheers
2air'
Name:	waterpump and pre filter.jpg
Old 02-28-2006, 08:20 AM   #11
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
really a fuel filter
Yeah, Cosmotini, my first thought was it was off my 1975 BMW 2002's fuel line! Except no plastic stuff on the beemer would have lasted this long.
It's pretty cool this forum can quickly and successfully generate good feedback for questions like this. What a team!
DreamStreamr is offline   Reply With Quote
Old 03-05-2006, 09:31 PM   #12
1976 25' Caravanner
Campton , New Hampshire
It's an inline sediment filter . From the looks of the color you should really replace it , pretty cheap at almost any RV store , if it comes apart you may be able to just get an element . It started out clear if that tells you anything.
ticki2 is offline   Reply With Quote
Old 04-04-2006, 11:58 AM   #13
AirstreamGypsy's Avatar
1961 16' Bambi
Mancos , Colorado
Send a message via Skype™ to AirstreamGypsy
water and pumps and pipes, oh my!
I feel pretty good about the gobbledy gook of pipe under my goucho after looking at GenDissaray and 2air's photos!
I wish my Bambi still had the old pump and filter. It came with nothing.... Replacing the o ring is a great idea but remember the old adage "if it ain't broke etc." I have had to replace both the pump and the accumulator and they were only in there since I first installed them in '99. Ah modern technology.
AirstreamGypsy
___________
Charter Member FCU WBCCI 1818 CP(Courtesy Parking) Wi-Fi
My Earthship
AirstreamGypsy is offline   Reply With Quote
Old 04-04-2006, 12:35 PM   #14
_
Originally Posted by AirstrmGypsy
I feel pretty good about the gobbledy gook of pipe under my goucho after looking at GenDissaray and 2air's photos!.
hi airstrmgypsy
did you say gobbledygook?
here a shot of the street side plumbing in mine.....before the interior went in....
and another of the whole shebang just as they started to hide it.....
amazing really.....and that most of the critical spots can still be accessed...i hope.
click on the pix for a larger view......
cheers
2air'
Name:	did you say pipes.jpg
ID:	20153   Click image for larger version
Name:	got pipes.jpg
