Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 07-04-2015, 08:10 PM   #1
gator.bigfoot's Avatar
KW , Ontario
what is this contraption under the sink
located under the bathroom sink connected to the white pex. Some thing with a clear lid. Just wondering.
gator.bigfoot is offline   Reply With Quote
Old 07-04-2015, 08:13 PM   #2
dznf0g's Avatar
Oswego , Illinois
That is a backflow preventer for the black tank flusher. They are prone to failure while using the flusher, so keep a close eye on it.
-Rich-
Old 07-04-2015, 11:53 PM   #3
1974 Argosy 20
Kooskia , Idaho
Yes a back flow preventer. The common problem is that they must be blown out with compressed air or they will freeze in the winter in a cold climate. You cannot just pour antifreeze in them either, they need pressure to push it through the valve.
Old 07-05-2015, 08:34 PM   #4
KW , Ontario
Is there are part number on this. I think I might just replace it since I'm having issues where my pump doesn't shut off sometimes. I can't find any leaks, but for some reason the pump will just start to run without using any water and then won't turn off. When I turn it off manually and then turn it on again it is quiet.
I've always blown out the lines and then filled them with anti-freeze, but perhaps it is just defective.
Old 07-05-2015, 11:38 PM   #5
1974 Argosy 20
Kooskia , Idaho
The unit in question does NOT connect in any way with the pump or fresh water system in your trailer. It is between the black water tank and the black water tank flush inlet on the outside of your rig. So, it cannot be responsible for the pump issue you mention as it does not connect with it at all. The only way water will flow through it is if you connect a hose to the black water tank flush inlet. One reason they become damaged by freezing is that people forget to blow them out thinking they are part of the regular fresh water piping.
Old 07-06-2015, 07:54 AM   #6
1998 30' Excella 1000
Livingston , Texas
I winterize with antifreeze. One item on my checklist, is to hook-up the short hose to the no-fuss-flush and open the valve for a few seconds.
Siegmann is offline   Reply With Quote
Old 07-07-2015, 09:53 AM   #7
KW , Ontario
ok. I just blow the thing out since putting antifreeze in is a bit difficult without a separate pump.
Under sink connections '70 Sovereign gparker Sinks, Showers & Toilets 0 08-06-2006 11:31 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
Under sink drinking water filter wacnstac Water Heaters, Filters & Pumps 7 04-05-2006 03:01 AM
Need a Water filter under sink w9det Water Heaters, Filters & Pumps 7 06-29-2005 06:15 AM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
