When I crawl under the Stream (2013 - 23ft International) on the driver side, forward of the tires I see 2 "T" handled valves. One is white plastic, the other is brass with threads and is stamped with something like "0.5 psi max" I think. What are these and what role do they play in winterizing?
The other two are your hot and cold low point drains. If you look under your sliding pantry, I believe you'll find a panel that snaps off like your water heater in the bedroom. Inside are two more knobs that are also low point water drains.
You'll know them well if you learn how to winterize your trailer.
Good Luck!
2013 25 FC FB (Twin)
2013 Suburban 2500
