Old 08-06-2014, 01:03 AM   #1
alumascoupe's Avatar
1966 26' Overlander
Frozen , Tundra
Waterless P Traps ?
My Overlanders original design has no crossmembers under the bathroom floor in order top to clear the black tank and that poor sheet of plywood (although 3/4" now!) has to support the tub, toilet, blacktank, univolt, batteries, and water heater ! Like they put all the heaviest stuff on the weakest section of floor.
My old floor had an 8" hole cut in the floor under the tub to clear a conventional P trap.
If I can get away with a waterless P trap, not only would the floor be more structurally sound without the giant hole, there would be more room under the floor for a bigger Blacktank and one less entry point to seal off for heat and critters.
Has anybody had any good or bad experiences (or smells) with a waterless trap ?
alumascoupe is offline   Reply With Quote
Old 08-06-2014, 05:00 AM   #2
No such thing.
The water, stops the odors.
Old 08-06-2014, 05:47 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by Inland RV Center, In View Post
No such thing.
Actually there is, and Interstates have them. It's not really a P-trap, of course, but it accomplishes the same purpose. Called a Hepvo Waterless Valve (Hepvo Waterless Valve). It's a type of check valve, and can be installed vertically or horizontally, so it's ideal for tight under-floor areas in an Airstream. It stops the odors as well, and since it doesn't retain water, water can't splash out while you're in transit to let odors in, so it's even better than a P-trap in that regard. Add to that the fact that it doesn't have to be winterized because it's normally dry to begin with, and you've got an excellent P-trap replacement.
Oh, and since it's a one-way valve, water can't back up in it if you overfill the tank.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-07-2014, 03:16 AM   #4
1966 26' Overlander
Frozen , Tundra
Andy you're right, got me on a technicality ! I've become the poster usually chuckle at !
Protaganist, Wow ! you've got me sold , if you've got no odors, thats what I was concerned of. I never even considered the winterization , backsplash, or overflow benefits. Thank You !
Old 08-07-2014, 03:41 AM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
The Hepvo valve may require occasional maintenance or need replacement when the membrane fails, so access to it is required. There would still be a need for a hole in the floor if there is no access from above.
Alan
Old 08-07-2014, 03:47 AM   #6
Or an access hole in the belly pan to provide access from below. Take your pick.
WBCCI #1105
TAC LA-4
Old 08-08-2014, 08:15 PM   #7
1966 26' Overlander
Frozen , Tundra
No worries, My drain is accessible via a removable panel alongside the tub. So theres a membrane that can wear out ? Any idea if this membrane is a type of one way fabric or is it like a flapper ? Not that it matters, just curious.
Old 08-08-2014, 08:59 PM   #8
1976 Argosy 26
Fair Oaks , California
Purchased mine here.
HepvO Self Sealing Waterless Waste Valve
Argosy Heir is offline   Reply With Quote
Old 08-08-2014, 09:31 PM   #9
Someday'59's Avatar
Powder Springs , Georgia
Images: 18
We installed a Hepvo waterless P trap on our tub and have been happy with it. It is accessible through removable panel on the bellypan.
~Lynnetta
my restoration & travel blog:
http://someday1959.blogspot.com
Someday'59 is offline   Reply With Quote
Old 09-02-2014, 05:50 AM   #10
1972 27' Overlander
Denver , North Carolina
Just bought two of them. They make sense to me. You can install them horizontally or vertically, and up to 6' away from the fixture. Mine will be behind the hatch.
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 09-02-2014, 07:39 AM   #11
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
Somewhere in this thread by "Timzog" there is detailed info on the consideration of, installation of, and use of either this trap or a similar one.
http://www.airforums.com/forums/f379...ion-74611.html
Brings up the whole question of marine fittings . . .
Lots of possibilities.
youngpeck is offline   Reply With Quote
Old 09-05-2014, 08:17 PM   #12
1972 27' Overlander
No post. The ones I bought from Hepvco meet building standards for homes. I do not like the idea of cutting yet another hole in my floor to support an antiquated technology.
Waterless Car Wash Bluto Cleaning, Stripping & Polishing 11 01-08-2012 11:17 AM
HEPvO waterless valve hampstead38 Sinks, Showers & Toilets 3 09-12-2010 07:23 PM
Speed Traps Janet H On The Road... 48 12-12-2007 06:12 PM
