Old 02-04-2009, 09:40 AM   #1
1996 25' Excella
Delta Junction , Alaska
Water tank drain valve
Hello,
After a few trips up and down the Alcan Highway and around Alaska, we have had to replace the plastic drain valve to the water storage tank (twice). The gravel would simply break it off. Imagine our surprise when we would get to a rest area to have a cup of coffee or use the amenities and discover the well had run dry. The designers obviously didn't bear in mind these beauties would be pulled over anything other than hard surfaced roads. What I did to eliminate the problem was to cut a 4" piece of 1" aluminum angle and attach to the bottom of the trailer belly about and inch or so forward of the drain valve. To this I cut and bolted a 4"x3" piece of rubber mudflap. I've never had another problem with losing or damaging the valve. Just thought someone could use the tip.
Brett
brhulen is offline   Reply With Quote
Old 02-04-2009, 11:47 AM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Welcome to the Forums and thanks for this fix tip/idea!
TB & Greg and Abbey Schnauzer
#3954
Old 02-04-2009, 04:04 PM   #3
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
1/2" 90 degree brass petcock valve,disassemble,1/2" fender washer.drill 2 holes at 1/8 in from centered sides slip washer over 1 side of valve and solder in place reassemble valve after it cools.r&r plastic valve with this contrivance and you are done for good.
crestonrv is offline   Reply With Quote
drain valve on fresh water tank: '79 Argosy 6.0 campman All Argosy Trailers 7 01-26-2009 06:59 PM
Fresh water tank drain valve location? trilink3 Fresh Water Systems 8 11-04-2007 08:23 PM
4th broken water tank drain valve gklott Fresh Water Systems 17 02-12-2007 01:50 PM
Water drain valve? ldetsf LP Gas, Piping, Tanks & Regulators 2 11-29-2006 04:57 PM
['77 23' Safari] Drain valve location for freshwater tank ? Mike B Fresh Water Systems 6 11-05-2003 10:22 PM
