Old 09-06-2016, 12:09 PM   #1
2013 23' International
foster , Kentucky
Water Tank 2013 International Airstream
We were camping this past weekend. Typically we do not hook up the water hose...we just use fill up the water in the tank and use the pump. We turned on the pump and noticed the pump kept running. My husband noticed a water on the ground underneath the airstream. He proceeded to crawl underneath and thought maybe the lever had come loose somehow. He went to adjust it and it fell into his hands. Needless to say he was not happy. The piece must have been a bad part. There is part of the threading in the other part. We bought some sort of gadget that is supposed to get the broken off parts out but the part that is attached to the tank just keeps turning ...there is no way to make this work ..what are we missing?
kfthomas is offline   Reply With Quote
Old 10-09-2016, 12:00 PM   #2
2013 23' FB International
Methow , Washington
Water tank drain valve failure
While boondocking this past week, experienced essentially the same thing. I was able to obtain a new "close" 90 degree fitting, but have not been successful in removing the remaining broken nipple threads from the tank, so I can install the new fittings.
When I tried to remove the broken nipple from the tank with an easy out type of tool, the fitting seemed to turn up in the tank. Did you receive any responses to your post, I did not see any.
Any experiences would be appreciated, we need to get back on the road.
Rufrider is offline   Reply With Quote
waste water tank and fresh water tank size 1964 safari jwmonty72 Waste Systems, Tanks & Totes 1 06-28-2016 04:21 PM
Replacing black water tank with grey water tank cheetah1 Sinks, Showers & Toilets 25 10-02-2014 05:26 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Help! My '63 overlander need plumbing, hot water tank, and water supply tank! aprilr 1960 - 1964 Overlander 9 11-30-2011 08:52 AM
