Old 09-30-2014, 10:40 AM   #1
1992 29' Excella
THE RANCH , Texas
Water system
After hooking up shoreline water the fresh water holding tank fills up. Is there a check valve between the fresh water holding tank and the water pump or is the check valve built in the water pump?
TAC TX 42
HOOK 'EM HORNS
GOD BLESS AMERICA!
COURAGE IS BEING SCARED TO DEATH BUT SADDLING UP ANYWAY........JOHN WAYNE
callie is offline   Reply With Quote
Old 09-30-2014, 10:46 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Both. There is a check valve on the municipal water inlet so that water from the pump doesn't try to flow out the inlet, AND a check valve so that water from the inlet doesn't backflow through the pump. Sounds to me as if the check valve on the pump isn't working properly.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-30-2014, 11:10 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
The pump itself is the check valve. But unlikely that it has failed.
Check your control panel your trailer may have "Auto Fill". If so it may be turned on. There should be a light for the auto fill.
2004 Excursion 4x4
Water Filtration System for Drinking Water kentuvman Fresh Water Systems 6 02-11-2013 08:34 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Water filter system 53flyingcloud Our Community 2 07-05-2002 04:43 PM
Leak in Water System Rich Palmieri Fresh Water Systems 6 06-27-2002 06:17 AM
