Old 11-30-2012, 04:07 PM   #1
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Water Softener
I am wintering in Florida. The water here is very hard. i have often thought of adding a water softener. I have seen those that use ordinary table salt. Some of these systems are very compact, and work silently. For the money ($250) they seem like a good thing.
Anyone have experience or an opinion from use?
Thanks in advance!
Old 11-30-2012, 06:05 PM   #2
dznf0g's Avatar
Oswego , Illinois
Santa has placed one in my basement along with a new filter. Haven't used it yet though.
Elves built it here:
PortsBlue 200 In-Line Mobile Water Softener
-Rich-
Old 11-30-2012, 07:37 PM   #3
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I have a Flow pur softener
Mark 8000
and no water goes into my coach unless it has gone through the softener first. I have used it for about 2 years now and highly recommend it.
Cheers, Dan
Smartstream is online now   Reply With Quote
Old 11-30-2012, 08:26 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We use a On The Go softener for all water going into the Airstream.
Better for plumbing, no hard water spots on the sinks, little if any shower buildup, less soap, and the wife loves it for her hair and skin.
Might be the best accessory you can get for your Airstream.
doug k
Old 11-30-2012, 09:28 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
Thanks in advance!
They do work but are fiddly to set up and to regenerate. If you don't move around much they may work out OK for you.
I generally fill up on soft water at home before heading out on the road.
Old 12-01-2012, 07:58 AM   #6
2010 27' FB International
La Crescent , Minnesota
Had a Water Stick for several years. Would not travel without it!
Jay
mjayjensen is offline   Reply With Quote
