Old 11-10-2014, 09:49 AM   #21
2001 30' Classic S/O
Westcliffe , Colorado
Update 4
4th Update,
Problem definitely seems to be a crack in the input line. This vintage trailer used the hard plastic lines with brass 90 degree fittings that are held in place with what appears to be a steel band. I see no way remove those bands.....any ideas out there?
SueYour is offline   Reply With Quote
Old 11-10-2014, 10:20 AM   #22
1974 Argosy 20
Kooskia , Idaho
Originally Posted by SueYour View Post
4th Update,
Ah, gray polybutyl lines I bet. I use a Dremel tool with a cut off disk to cut the bands. The bands are generally a copper alloy material but look dark like steel.
Old 11-10-2014, 03:27 PM   #23
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
My 86 has polybutyl lines also. There are PEX to Poly fittings that you might find easier to make the inlet line repair. I use them so I don't have to buy two different types of crimping tools. They also make "shark bite" type "push to connect" or PTC fittings that seal on the OD of the poly to PEX tubes. I have used those also. See one on the left in this crummy photo. It has been there three years and about 10,000 miles.
David
Name:	1212 New Cold Hot Main.jpg
dbj216 is offline   Reply With Quote
Old 11-10-2014, 06:43 PM   #24
Update #5: Finally able to replace the line from the FW tank to the pump with no leaks! Water system working somewhat. Very pulsating water stream from facets and pump does not shut off but it looks like no air leak up to the filter. After the pump is turned off the water on the input side retracts to the FW tank. Still need to eliminate filter because running antifreeze thru the pump seems really good. Hopefully I'll have a final update in two days. Thanks to EVERYONE for your help! Airstreamers are great!
Jim (using my wife's acct)
Old 11-10-2014, 07:14 PM   #25
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Heck, don't all us DHs use the wife's account?
David
Old 11-11-2014, 11:59 AM   #26
Vagabond Bob's Avatar
Crestone , Colorado
Jim I followed this for a while. Let me know if you need some help. I have the same trailer down in Salida. Maybe we could start a support group!
Vagabond Bob
Salida, Colorado
2001 30 ft 70th. Anniversary
With slide out
Vagabond Bob is offline   Reply With Quote
Old 11-20-2014, 03:39 PM   #27
Bob,
Thanks for the offer. It would be great to get together sometime and commiserate.
Old 11-20-2014, 03:41 PM   #28
Update #6
After changing pump, accumulator, input line, and output line, problem appears to be resolved. Thanks to the great support and input!!
Old 11-20-2014, 06:04 PM   #29
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Jim, thanks for the closure on this one. Wow, you changed a lot of parts! Any idea which one was the biggest contributor to the problem? Maybe that new pump was defective some how and you replacing it made all the difference? Maybe it wasn't the inlet line at all.
David
Old 11-21-2014, 07:30 AM   #30
I think there were multiple problems but the main culprit was a split line. I'm guessing it may have split during winterization, but don't know for sure.
water pumping back to street mmette00 Fresh Water Systems 5 05-13-2013 07:31 AM
Pumping anti-freeze thru water lines FredV Winterizing, Storage, Carports & Covers 39 10-28-2012 09:35 AM
Water pump not pumping Isadora Water Heaters, Filters & Pumps 5 05-06-2008 07:49 PM
fresh water tank level and pumping Lumatic Fresh Water Systems 8 12-24-2007 05:51 PM
Pumping out an Airstream honeywagon Waste Systems, Tanks & Totes 3 08-05-2006 08:08 PM
