Old 11-20-2014, 06:04 PM   #29
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Jim, thanks for the closure on this one. Wow, you changed a lot of parts! Any idea which one was the biggest contributor to the problem? Maybe that new pump was defective some how and you replacing it made all the difference? Maybe it wasn't the inlet line at all.
David
Old 11-21-2014, 07:30 AM   #30
2001 30' Classic S/O
Westcliffe , Colorado
I think there were multiple problems but the main culprit was a split line. I'm guessing it may have split during winterization, but don't know for sure.
SueYour is offline   Reply With Quote
water pumping back to street mmette00 Fresh Water Systems 5 05-13-2013 07:31 AM
Pumping anti-freeze thru water lines FredV Winterizing, Storage, Carports & Covers 39 10-28-2012 09:35 AM
Water pump not pumping Isadora Water Heaters, Filters & Pumps 5 05-06-2008 07:49 PM
fresh water tank level and pumping Lumatic Fresh Water Systems 8 12-24-2007 05:51 PM
Pumping out an Airstream honeywagon Waste Systems, Tanks & Totes 3 08-05-2006 08:08 PM
