Old 06-22-2014, 08:41 AM   #1
Louisville , Kentucky
water pump replacement
Hi all; purchased a 74 Excella 500 resto that was started by previous owner and was frankly botched. When mounting new water pump i know the best place is level with tank outlet, but i have no space for the inlet screen and the pump under the floor. Will it still work if mounted on the floor in the sink cabinet or will that be too much lift to self prime?
Kyowner is offline   Reply With Quote
Old 06-22-2014, 10:02 AM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I have a SHURFlo pump (3 years old) with the SHURflo brand inlet filter screen and it sits on the floor by the outlet to my fresh tank. When I unscew the cup there is just enough room to remove the cup and screen to drain it when I winterize. If you have SHURflo components you might double check.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 06-22-2014, 10:33 AM   #3
1974 Argosy 20
Kooskia , Idaho
There is enough suction on the intake side of the pump so it can be located above the tank, probably by 2 or 3 feet. So, locating it a few inches above the tank will be no problem.
Old 06-22-2014, 11:18 AM   #4
Thank you!
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
Water Pump Replacement ? Craig Electrical - Systems, Generators, Batteries & Solar 2 09-11-2006 07:55 AM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
water pump replacement - what is best? nola Water Heaters, Filters & Pumps 5 07-23-2006 03:19 PM
