Old 02-13-2015, 09:30 AM   #1
1976 23' Safari
Water Pump Rebuild Kit
Hi, New to the forum. I have a 1976 Bambi I have inherited from my Dad. I used it about 10 years ago when the children were small and we went camping nearby but never had to do any maintenance. Our water pump is leaking and I have a friend that will take apart and rebuild if I can find a kit or at least the gaskets. It is the original PAR 36800-1000. He said it is all working, just leaking (through the diaphram?). Any clue on where to find kits?
Also when my potable water gets full, it is leaking - guessing a crack in the top part of the tank. How do you repair a water tank? I read once to use soldering iron and milk jugs and "weld" it. Any tips?
Front rock guard is cracked and I have gorilla tape to use - any drawbacks? Also need awning. That is about all I can guess is wrong - for now! LOL
I also saw a thread on tankless water heater and guessing that might be an avenue for me. I will not really need gas heater because we would be in a camp site with hook ups 95% of the time. The water heater works well, but I have no idea how to light it. Unfortunately Dad passed away about 7 years ago and not here to tell me the tips and tricks.
Thank you, Pam
DancingGoat is offline   Reply With Quote
Old 02-13-2015, 09:44 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Welcome
These folks have the rebuilt kits in stock.
Jabsco 36800-1000 Pump
MICHAEL
Old 02-13-2015, 10:55 AM   #3
1976 31' Sovereign
Oswego , Illinois
Water easy to light for your yr. AS, make sure gas turned on, control on heater has turn knob that says pilot and on, turn to pilot depress red button turn striker or use gas match on pilot in burner tube hold button down until pilot lights, release red button if pilot goes out redo, turn top knob to on. If will burner will not light probably spiders in orifice, simple to clean, disconnect burner and gas line blow out w/air, clean orifice w/ cutting torch cleaner tips. Also make sure large control knob is turned for temp. desired from low to high.
« rbi | Top | filtration »
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Hitch Latch Rebuild Kit? kry226 Hitches, Couplers & Balls 24 03-09-2013 07:47 PM
AquaJet ES water pump rebuild kit? Wingeezer Water Heaters, Filters & Pumps 3 06-03-2011 01:15 PM
Rebuild PAR 6800J (Jabsco 36800) or Replace with New Pump trevisgardne Water Heaters, Filters & Pumps 3 05-02-2007 09:20 AM
rebuild kit for water pump 76 sovereign chris's 67 Fresh Water Systems 2 03-06-2007 08:18 PM
