Old 02-06-2015, 08:25 PM   #1
1973 25' Tradewind
Beautiful , Oregon
Water Pump Position wall or floor
Hi Folks
I was hoping to get an opinion or two about water pump position. Is vertical on a cabinet wall or flat on the floor the preferred position. Of course, vertical takes up less floor space but is there any performance difference. Any other advantage or disadvantage.
Thank You in advance
Tony
Tony S is offline   Reply With Quote
Old 02-06-2015, 08:30 PM   #2
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Floor is the RV Industry standard.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 02-06-2015, 08:34 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Would it be harder to initially prime when higher? Would it have trouble draining for winterizing? Does the mounting instructions give advice on position?
Doug and Cheryl
Old 02-06-2015, 08:38 PM   #4
AIR #8691
2006 25' Safari SS SE
Northern , Virginia
Interesting question. Since itís essentially a motor attached to a pump, I donít think it makes any difference how you mount it. Should work just as well upside down. Try it and see. Just make sure all the water is out when you winterize it.
JStanley is offline   Reply With Quote
Old 02-06-2015, 08:42 PM   #5
DFlores's Avatar
1968 22' Safari
This may be a simple view, but I would think vibration would be more difficult to mitigate in a vertical installation thus leading to a noisier pump
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 02-06-2015, 08:51 PM   #6
dkottum's Avatar
Thinking about the noise and vibration it sends throughout the Airstream, one might consider mounting it suspended on heavy rubber bungees at four corners.
Doug and Cheryl
Old 02-06-2015, 09:01 PM   #7
1974 27' Overlander
Twisp , Washington
If you're talking about the typical Shure-Flo type pump, it'll work just fine either way. However, if you do mount it vertically, make sure the motor is above the pump, just in case something leaks. Later.
Dave
daved20319 is offline   Reply With Quote
Old 02-06-2015, 10:09 PM   #8
1973 25' Tradewind
Beautiful , Oregon
The vibration is a good point. I probably will mount on floor with some rubber I have around from a truck bed liner.
Thank you all
Tony
Old 02-06-2015, 11:13 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I think you will find that the motor does not have thrust bearings to support the vertical position of the shaft in the pump. While it may run for a while. I believe it will develop end play and eventually fail.
Old 02-07-2015, 07:08 AM   #10
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
I'm agreeing with Twinkie on this one. We have some propane exhaust fans I use on my job that failed for the same reason. Mount them horizontal and they run for years. Mount them vertical, and you get about six months out of them, but they do run continuous... YMMV.
-Red, isolating his water pump horizontally...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 02-07-2015, 07:58 AM   #11
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Read the directions when all else fails.
Old 02-07-2015, 08:13 AM   #12
billiards's Avatar
rochester , Minnesota
Floor would be best choice......consider the bushings on the armiture of the motor,the flat surface is the long portion of the bearing.....it should be on the floor otherwise the friction surface is riding on the wrong art of the shaft, one should
Keep this in mind with any electric motor....of course it will work in any position for a length of time.
billiards is offline   Reply With Quote
Old 02-07-2015, 09:04 AM   #13
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
My old Alfa had the pump, with the rubber feet, mounted horizontally on a 3/8" piece of plywood wall. This wall was flexible, more of a cover piece to finish off the storage compartment. One big sounding board, you could hear it throughout the rig.
Never failed though.
"Chip Tank" is in Flagstaff Az.
CDONA is offline   Reply With Quote
Old 02-07-2015, 11:38 AM   #14
1973 25' Tradewind
Beautiful , Oregon
Thanks.
Will mount on floor
Tony
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
Water on floor, wall, seat, outlet nesvt General Repair Forum 16 07-24-2012 09:04 AM
Best position for water pump and lines bwaysteve Water Heaters, Filters & Pumps 1 01-19-2010 11:42 AM
Water heater by-pass valve position? TennisMan Water Heaters, Filters & Pumps 1 01-10-2009 09:45 PM
Water valve position question chuman70 Fresh Water Systems 5 06-03-2007 06:23 PM
