Old 02-04-2009, 09:28 AM   #1
1996 25' Excella
Delta Junction , Alaska
Water pump losing prime
Hello All,
We bought our 1996 Excella new in early 1997. Our 12v water pump loses its prime after a day on the road. When I looked into this, the service manager tells me it is common due to the location of the pump being above the tank. I find this a little hard to believe, but after having them replace the pump it still did the same thing, so perhaps they're right. I was thinking a simple one way valve ought to solve the problem. Currently the only way to get the water flowing is to empty the closet, and prime the pump by pouring water into the filter housing. Has anyone else had this problem and if so what have you done to fix it?
Brett
brhulen is offline   Reply With Quote
Old 02-04-2009, 11:50 AM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Brett,
Both our '87 and '06 have the water pump higher than the potable water tank and we have never lost a prime that I know of. I think the pumps already have a mechanism that prevents backflow. Maybe you have a slow leak in the leg between the water tank and the pump inlet??? Small hole in tubing? Hose clamps not tight? Leak in the filter bowl? At least that is where I would start, especially if it is a new water pump.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 02-04-2009, 04:11 PM   #3
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
pump has check valve to prevent that.does your pump have strainer/prefilter on it? they can cause it to loose prime by leaking air back to tank,won't show as leak unless you pressurize pick up line (normally is under vacumme).next guess is damaged diaphram in pump.
crestonrv is offline   Reply With Quote
Old 02-04-2009, 04:15 PM   #4
Originally Posted by brhulen View Post
Hello All,
Brett
The pump can lose it's prime, if the intake hose is bad, if the inline filter is bad or cracked, or if the internal pump valves are bad.
Any one or more of those problems will provide that grief.
What brand and model pump do you have?
Old 02-04-2009, 05:43 PM   #5
1960 24' Tradewind
Riverside , California
The Shurflo pump will prime from 6', your closet floor may be 12" above the bottom of the tank
PUMP
Type: 3 Chamber Diaphragm
Ports: 1/2-14 NPSM-Male.
Liquid: 130 F [54 C] Max
Prime: 6 feet [1.82 M]
Inlet PSI: 30 PSI [2.1 Bar] Max
Run Dry: Yes
ELECTRICAL
Motor:
Greg
ZoomZoom is offline   Reply With Quote
Old 02-04-2009, 06:12 PM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Prime Problems
I agree that you probably have some sort of leak on the intake side.
You could try printing this list and attaching it to the pump: 2 3 5 7 11 13 17 19 23 29 31 37 41 43 47 53 59 61 67 71 73 79 83 89 97.
Vaughan
Old 02-05-2009, 04:59 AM   #7
DEITZ645's Avatar
ARGHHHHHH...Math humor
As jimmy Buffett says..."Math Suks"
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 02-05-2009, 07:18 AM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
On my 71 my fairly new Sureflo has trouble pumping just after an empty fresh water tank is refilled. It's been like this since installed. The tank needs to be full or nearly so before the pump starts actually puping water. After that no problem. Any ideas what's going on?
Old 02-05-2009, 07:55 AM   #9
1996 25' Excella
Water pump
Thanks everybody! Well when springtime comes, (it was -42 degrees yesterday morning), and as time allows I'll dive back into the closet and check for some of the solutions offered. I'm betting on the filter housing. It is a new Shureflow pump installed by the A.S. service department, so I tend to think it has nothing to do with the pump. Even the manager agreed it seems to be a common problem. I haven't seen any indication of a leak, except where I spill water trying to prime the darned thing. If nothing else maybe I'll install one of those squeeze bulbs on the suction side like they use on outboard motors to prime it. Or perhaps I could just buy another pump to prime the pump, to prime the pump, to prime the pump etc. I must say my darling wife is getting tired of having me empty the closet each time and listen to me rant.
Old 02-05-2009, 10:31 AM   #10
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
Another sure sign of a leak on the intake side of the pump is air in the water. A leak on that side may not drip, but you may see "spitting" when running water into the sink. Our previous trailer had a crack in the filter housing which was impossible to see when installed deep inside the cabinet.
If you do not have any air in the water stream, I would be suspicious of the pump innards.
(Would that be a stream of air in your water stream in your airstream?)
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
sander17 is offline   Reply With Quote
No Prime, or no pump? blaisew Fresh Water Systems 5 12-14-2007 12:38 PM
prime water system? chapparel Fresh Water Systems 5 06-09-2007 08:39 AM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
Water pump does not prime ipso_facto Water Heaters, Filters & Pumps 12 04-18-2004 10:40 AM
Water pump won't prime??? roessler Water Heaters, Filters & Pumps 5 01-22-2003 08:21 AM
