Old 10-09-2015, 04:22 PM   #1
BessieB's Avatar
1997 21' Excella
Carson City , Nevada
water pump just runs but doesn't suction
I am assuming it is time to RIP my water pump. It was working all summer and now I am on the road. The pump just does the little motor running thing but no other action. The pump was replaced in 2006 from the original 1997. Primed over and over, but the pump is not sucking from either tank, hot or normal. Is it time to get a new pump? That is my thought.
BessieB is offline   Reply With Quote
Old 10-09-2015, 04:30 PM   #2
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
New one, they're not that costly in the overall cost of things.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 10-09-2015, 05:18 PM   #3
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
The pump might not be the problem - there might be an air leak somewhere. I'm going through a similar situation and I eliminated the pump as a problem by removing it and testing it with a bucket. It worked fine. I figured out what my problem was and it wasn't the pump so at least I saved wasting $200 on a new one.
Good luck!
John
P.S. Here's my tale of woe: http://www.airforums.com/forums/f445...es-141995.html
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 10-11-2015, 11:31 AM   #4
BessieB's Avatar
1997 21' Excella
Red face Problem fixed......
Soooooo......... the reason my pump was not pumping....... The tank drain was not fully closed. So for over the course of time that I filled the tank and finally hit the road. So by the time I was actually using the trailer, the tank was on its last gallons. Just enough of a drip, that I had an empty water tank. So of course I took for granted that the water tank was full and it was not at this point. Soon...... do I get the dumb award of the year?
Old 10-11-2015, 12:00 PM   #5
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Not even close.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 10-11-2015, 12:16 PM   #6
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Not even close.
Youll need to practice a great deal more to win THAT award
mayco is offline   Reply With Quote
Old 10-11-2015, 01:52 PM   #7
1974 Argosy 20
Kooskia , Idaho
I got mine about 1980 when I was pretty new to Airstreams. It would take too long to tell, but it was well deserved.
Old 10-12-2015, 12:30 PM   #8
Springville , Alabama
I had same problem. I inspected the incoming line, and found a cracked housing around the filter. It was sucking air, and not priming. $6 easy repair!
driftwood1 is offline   Reply With Quote
Old 10-12-2015, 12:54 PM   #9
Center Moriches , New York
Have you checked the stainless steel screen at the water intake to see that it's not fully clogged?
NY24 is offline   Reply With Quote
Old 11-16-2015, 01:21 PM   #10
gpt
2014 25' FB Flying Cloud
sequim , Washington
had that happen and once i was finally was able to extend my arm far enough to grasp the filter assembly, i found it loose, a quick turn and it was back in action. i suppose it might have vibrated lose or perhaps it was never tightened in the first place. but all is well after that minor inconvenience.
gpt is offline   Reply With Quote
Old 11-16-2015, 02:32 PM   #11
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I had an algae problem - swamp water contaminated the well - a little pool shock treatment and all was good except that the filter was clogged. Took it out, cleaned it, and reinstalled. Worked for about 3 days and then started hammering and finally quit. I assumed I had another glob of algae even though I had some heavy bleach in the tank...
Went to Alumalina and Overlander63 found that the filter had worked loose again & was sucking air. Guess I've lost some hand strength.
Paula
Old 02-26-2016, 01:55 PM   #12
1968 22' Safari
Dorchester , Illinois
Red face
Add me to the Feeling Really Dumb crowd. I filled my tank, pulled into campground slot and turned on pump to fill hot water tank. Two days later I couldn't figure out why I was out of water. (Hint - my water heater holds 6 gal).
Steve
Missed-Em is offline   Reply With Quote
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
WaterPump Runs but Doesn't Pump Dreamnair Water Heaters, Filters & Pumps 10 10-10-2015 07:49 AM
Compressor runs but needle doesn't move! ericjan2 Classic Motorhomes 6 10-23-2012 04:34 PM
Water pump runs but no water comes out goswick Water Heaters, Filters & Pumps 18 07-05-2009 06:10 PM
WBCCI- Doesn't listen or just doesn't care Stream 1529 WBCCI Forum 30 09-29-2008 04:55 AM
