Old 10-25-2019, 07:38 PM   #1
Cary , NC
Water Pump in 2014 Flying Cloud 20'
I have never used my water tank or pump, because I try to camp with city water. I don't rough it!
However, I am in a campground with no water - silly me.
So I hear the pump operating, but no water from either Kitchen or bathroom sink.
What's up?
alreardon is offline   Reply With Quote
Old 10-25-2019, 08:43 PM   #2
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
What's up?
Assuming a full tank of water onboard, it generally takes mine quite a while for the pump to prime itself. Five minutes sometimes before all the sputtering is over.
That being said if it’s been years since the pump was run the rubber diaphragm may have disintegrated. The answer in that case is a new pump. I’d suggest a SHURFLO 4008-101-A65 if that’s the case. Much quieter than older pumps. https://www.amazon.com/dp/B00W5GCQC2..._0o6SDbCHQY4FE
daleyocum is offline   Reply With Quote
Old 10-25-2019, 09:40 PM   #3
Long Island , New York
Assuming your pump is still working, have you filled the water tank, and is the monitor reading 100%? Open a faucet or two when you turn the pump on. That might help the pump get its prime in order. Is the water heater full of water? When the trailer was last winterized, maybe some some hose connections at the pump were not reassembled correctly?
Remove the large drawer under the oven, and look into the pump area. Any water drips or sucking air sounds? To figure out how to take the drawer off its slides, look at the drawers between the fridge and the oven. If you look at the underside of the top drawer, when it is pulled out, you can see how to push on the orange release tabs on each side near the drawer front.
We have the same year and model, so hopefully the steps above will make sense. If you get some water out of one faucet at least, go around and bleed the air out of all hot and cold lines, including the exterior shower.
You might also want to read the owner's manual on this.
Good luck,
Peter
PS -- There is a thread specifically for our model, with many helpful fellow 20' owners available to help:
http://www.airforums.com/forums/f542...rs-127845.html
PS2 -- You should always use an inline filter when filling the water tank [and when using city water]. If you filled the tank with just a hose [no filter], you might have grit in the pump preventing it from getting its prime.
Old 10-30-2019, 01:51 AM   #4
What's up?
Have you sorted this out?
Peter
Water pump switch on a 2014 Flying Cloud 27FB Van1 2009-2015 Flying Cloud 9 06-04-2016 05:36 AM
Flying Cloud :: 2014 Airstream Flying Cloud gregwall Airstream Registry Discussions 0 05-05-2016 07:12 PM
2015 Flying Cloud 25FB water pump questions easler7267 Water Heaters, Filters & Pumps 18 06-03-2015 09:43 PM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 07:46 PM
