Old 12-17-2017, 06:18 PM   #1
Aubrey , Texas
Water pump and water heater
If you have water in fresh water tank can you turn the hot water on with the pump on. Do you turn water heater off when you are done
stujan is offline   Reply With Quote
Old 12-17-2017, 08:16 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
You can just leave the pump and the water heater on all the time if you want. The pump only pumps when the pressure drops when you are running water. The heater has a thermostat that turns it on and off.
Having said that, we don't do it that way. We turn the water heater on for a while in the am and a while in the early pm. We do not like it to run at night. And our water gets too hot if we leave it on all the time.
We generally turn the water pump off at night and when we leave the trailer. And of course the hot water heater is off on those times too.
Old 12-17-2017, 08:18 PM   #3
Aubrey , Texas
Thanks Bill just checking before I have a serious problem
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 07:46 PM
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 9 10-02-2013 11:55 PM
Hot water heater and water pump xo1rider 2011 - 2015 International 3 10-12-2012 07:55 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 08:01 PM
Water heater and Water pump, for now... howardtbell Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-21-2009 08:33 AM
