Old 09-02-2014, 02:03 PM   #1
1998 19' Bambi
Henderson , Kentucky
water pump
I just purchased my first airstream 2 weeks ago and I cannot get the water pump to come on. My airstream is a 2004 16 foot bambie. Is there a separate switch other than the one by the sink? Is there a switch on the pump itself under the seat cushion? Everything else works great.
Skurtis is offline   Reply With Quote
Old 09-02-2014, 03:47 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
If you have a 12 volt test light, that would be ideal to check if the pump is getting power. If you don't have a 12 volt test light, go buy one now.
They're pretty cheap at auto parts stores.
Old 09-02-2014, 08:43 PM   #3
1998 19' Bambi
yes, I have done that and no power is getting to the pump
Old 09-02-2014, 08:55 PM   #4
1976 31' Sovereign
Oswego , Illinois
Is there a in line fuse to pump? As I have never seen pump without fuse. Use tester to see if power comes into fuse and out or check fuse itself out of holder with continuity checker.
Old 09-03-2014, 10:13 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Also use the tester to verify switch functions correctly.
Peace and Blessings..
Channing
WBCCI# 30676
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 9 10-02-2013 10:55 PM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
water pressure or water pump? 59er Water Heaters, Filters & Pumps 3 07-01-2005 04:45 PM
Water Pump running, water is not... CampSayler Water Heaters, Filters & Pumps 4 09-23-2004 04:34 PM
