Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 08-19-2018, 05:47 AM   #1
1974 27' Overlander
rochester , Michigan
Water pressure very low at bathroom sink only
1974 Airstream Overlander good pressure at kitchen sink and bathroom shower but no pressure at bathroom sink? Is there a filter at sink or hot water heater that could be plugged?
freerider is offline   Reply With Quote
Old 08-19-2018, 06:08 AM   #2
r carl's Avatar
Lin , Ne
If there is a faucet aerator it could be plugged. Unscrew and inspect it. You can check if the water runs with it off too.
Old 08-19-2018, 06:09 AM   #3
Sag Harbor , New York
Is there some reason you have started a new thread? In your other one:
http://www.airforums.com/forums/f443...ow-185469.html
. . . your last post said:
[click on orange arrow to go there]
Originally Posted by freerider View Post
The shower toilet and bath sink are all low pressure I will try it hooked up to city water. Good idea. Do not check filter or screens. There is normal pressure at kitchen sink
Did you try the city water idea? Yes the bath sink might also have an aerator filter, or crud stuck in the H/C valves if they are OEM from 1974.
Peter
PS -- It gets really confusing here if more than one thread discusses the same topic IMO.
Old 08-19-2018, 07:01 AM   #4
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Having two threads can make for a lot of duplication of comments and it gets tough to work out which one to post in ....
Toilet is on the cold water line. Sink has two lines to it, one hot and the other cold. If the cold water line is plugged, that would not impact hot water to the sink .... thus the question in the other thread about "what about hot water". If the screen on the faucet / faucet valve is the issue, then both could be impacted.
Old 08-19-2018, 08:54 AM   #5
Please see reply in the other thread.
Peter
Old 08-19-2018, 10:01 AM   #6
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Smile
Peter
Actually, there are many threads in the Forums that discuss the same issue.....hitches and tow vehicles come to mind!
Larry C is offline   Reply With Quote
Old 08-19-2018, 10:19 AM   #7
Yes, but not started by the same person in quick succession, with the same basic problem IMO.
Old 08-20-2018, 06:53 AM   #8
1974 27' Overlander
I guess I only meant to reply to the original thread. The shower does have pressure and I will check the screen on the faucet today. Both the hot and cold water just dribble. Thanks and sorry about the duplicate post
Very low water pressure to galley and shower. Toilet and bath faucet work as usual lanewoodwork Sinks, Showers & Toilets 6 08-21-2017 02:24 PM
Very low water pressure using pump? Jeffndaile Fresh Water Systems 7 04-19-2017 08:42 PM
Low water pressure at toilet only russingr Plumbing - Systems & Fixtures 5 04-10-2017 02:37 PM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Very low water pressure for hot water from pump barrettjl Water Heaters, Filters & Pumps 21 10-27-2014 07:41 AM
