Old 09-16-2015, 09:20 PM   #1
Arlington , Virginia
Water Pressure Regulator Device
Do I need a water pressure regulator when hooking up to water at an RV campsite to fill up my fresh water tank? I've heard that it will serve as added protection from damage to my plumbing if there is too much water pressure at the site.
xCliff is offline   Reply With Quote
Old 09-17-2015, 06:26 AM   #2
dznf0g's Avatar
Oswego , Illinois
Many times , no...but sometimes, yes. I have seen campsite pressure as high as 80psi once. That could make for an inconvenient and messy repair. I have seen pressures all over the map, but that was the highest. I set my adjustable regulator to 50psi and never worry about it again.
-Rich-
Old 09-17-2015, 06:26 AM   #3
Keith Gantt's Avatar
2014 23' Flying Cloud
Woodstock , Georgia
It's built in my Airstream, so no need.
The Streaming Gantt's on Airstream Forums
Keith Gantt is offline   Reply With Quote
Old 09-17-2015, 06:31 AM   #4
dznf0g's Avatar
Oswego , Illinois
Keith, two problems with the AS internal one.
1) doesn't protect your hose (no biggie????? you be the judge)
2) the AS ones are plastic and prone to leaking (which I suspect is due to a high pressure event) This creates floor rot if it is a small leak over time and a mess if it is a large leak. I re-sealed mine and started using a brass Watts at the spigot. Everything, including the original AS regulator are now protected. Many folks remove the plastic AS one, and I probably will next time I have a reason to disassemble that area for repair or maintenance.
-Rich-
Old 09-17-2015, 06:32 AM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My trailer also has a built in regulator. One less thing I feel a need to buy just to have.
MICHAEL
Old 09-17-2015, 06:39 AM   #6
dznf0g's Avatar
Oswego , Illinois
I might add, mine did leak after a couple years of use. I noted water dripping steadily out the belly pan in that area. I removed and re-sealed the body halves and later got an external brass regulator.
-Rich-
Old 09-17-2015, 07:21 AM   #7
Wayward's Avatar
Cary , North Carolina
I have two fresh water hoses. Both now have hose clamps on them after the original crimped brass fittings were blown off by campground water pressure.
Now that I have corrected the "weak points", I suspect the internal Airstream pressure regulator cannot be far behind
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 09-17-2015, 07:37 AM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I believe it's the anti-backflow valve on campground spigots that locks water within your fresh water hose and your closed airstream plumbing system that bursts the hose. The water is trapped, expands as the sun heats it up and blows out the weakest point, which fortunately is your fresh water hose.
A second pressure regulator in the system will not prevent this, will it? Keeping an air bubble in your water heater or adding a water pressure accumulator to take up the expansion will.
Doug and Cheryl
Old 09-17-2015, 07:40 AM   #9
Wayward's Avatar
Interesting. Thanks!
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 09-17-2015, 08:16 AM   #10
dznf0g's Avatar
Oswego , Illinois
Theoretically, the AS regulator would prevent any pressure rise, due expansion in the hose from entering the AS. Wont help the hose though. I, quite frankly haven't noted this being an issue....maybe in the desert or very high sun load and high temp conditions, but I haven't experienced it.
-Rich-
Old 09-17-2015, 08:25 AM   #11
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
When I first got my preowned 2008 Classic 25fb in 2013 I installed my own regulator on the faucet then the hose to the Airstream. I thought their was something wrong as the water pressure seemed low. When I took my regulator off the faucet the pressure was normal. I had used this faucet regulator on my Casita (it doesn't have built in water regulator) without notice of pressure loss. Since then I just plug the hose directly into the Airstream and let it regulate the pressure. My water inlet is in a compartment in a lower access area so if the regulator would leak it would go straight to the ground. Hopefully its an easy job to replace if ever needed.
Kelvin
Old 09-17-2015, 08:40 AM   #12
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I have an external water pressure regulator to protect my hoses. I only use it at camp grounds where their water pressure is real high. Most camp grounds with high water pressure will let you know and/or sale/loan you a pressure regulator. One camp ground told us their water pressure can go higher than 100 lbs.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-17-2015, 08:46 AM   #13
AWCHIEF's Avatar
Images: 33
Anyone know what the internal regulator is rated at?
MICHAEL
Old 09-17-2015, 08:54 AM   #14
dznf0g's Avatar
Oswego , Illinois
This is what I found:
"This combination water pressure-reducer and check valve diaphragm design prevents high-pressure damage often caused by city water systems. This high performance water entry limit water pressure safely to a nominal 65 PSI (50 PSI inline version only) while meeting or surpassing all check valve code requirements."
Not sure exactly what that means though???????
-Rich-
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Water pressure regulator? yukionna Fresh Water Systems 7 06-16-2010 10:03 PM
Help!! Need access water pressure regulator Crawdad Fresh Water Systems 5 07-15-2007 02:16 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
Any PLUMBERS out there?? Pressure regulator, water pump questions SmokelessJoe Water Heaters, Filters & Pumps 65 01-11-2007 03:01 PM
