05-03-2016, 08:35 PM
#41
2012 25' Flying Cloud
Battle Lake
Originally Posted by ROBERTSUNRUS
Hi, Doug; I have been in camp grounds that have around 100 lbs of water pressure and for these I use an external water pressure regulator. This is to protect my hose and filter. Do you really think an accumulator will prevent this? I don't know the rating of a water hose, but I think 100 lbs is too much for one.
Bob, I think it will certainly help. I think an RV water pressure regulator at the spigot controls pressure only while there is water flowing through it. After that the campground back flow prevention device locks the water in your hose and the pressure throughout your hose and Airstream water system equalizes right to the faucets.
Then if there is thermal expansion in system due to heating of the hose in the sun and heating in the water heater, and there will be, it is up to the elusive air "bubble" in the water heater to take up that expansion. Or relief by the water heater thermal/pressure relief valve.
If these fail to protect your system and hose from thermal expansion, a water pressure accumulator can provide expansion space.
Doug and Cheryl
05-04-2016, 07:03 AM
#42
2015 25' Flying Cloud
GILBERT
45 psi, ck with /AS
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
05-04-2016, 07:28 AM
#43
Oswego
Originally Posted by cactusjk
Thanks!
Actually, 65psi...I posted it upstream....duh.
-Rich-
05-04-2016, 07:43 AM
#44
2015 23' Flying Cloud
2023 Interstate 19
Scottsdale
I am thinking of going with a 2 filter setup with a 55 psi external regulator for the campsite water source. Any problems with that approach with respect to flow, etc?
05-04-2016, 08:02 AM
#45
Sag Harbor
, New York
We always use an external water pressure regulator at the hose bib, and make sure we turn off the hose bib when we leave the site.
05-04-2016, 08:25 AM
#46
Oswego
Nope, I run an adjustable Watts regulator at the bib, through a water softener and filter...all at 60psi and everything is fine with flow and pressure at the AS fixtures.
-Rich-
05-04-2016, 08:45 AM
#47
2004 25' Classic
Prescott
I have been using one of those non-adjustable ones and have not been very happy with how low the water pressure is. I just bought this one ( http://www.amazon.com/Pressure-Regul...ater+regulator). What a difference! We now have good pressure inside again. I did some testing and found that a pressure setting of 60 psi is good and if you turn on the water pump at this setting, it will still run a short time. If I am understanding this, does that mean the water pressure using just the water pump is about 65psi.
Julia & Bob
W/ Deedee & Boo
AIR #30685
05-04-2016, 09:11 AM
#48
Oswego
That's a reasonable assumption, but if you look up the specs for your particular brand and model of pump, they usually tell you XX gallons of flow, at XX PSI.
-Rich-
05-04-2016, 01:07 PM
#49
2004 25' Classic
Prescott
Thanks Rich, I appreciate the reply.
Julia & Bob
W/ Deedee & Boo
AIR #30685
05-04-2016, 01:13 PM
#50
Walnut Creek
We see the larger regulators with a gauge included. Are the union style regulators of such poor quality that one of these upgraded regulators is a good idea? Appreciate any technical input, including life span. Thanks. Pat
05-04-2016, 10:30 PM
#51
2007 22' International CCD
Corona
The cheap brass fixed regulators don't allow as much flow as the ones with a gage on them. I had one, and it didn't flow enough volume for the tankless water heater to work right at a campground with somewhat low water pressure. Tossed the darn thing, got the better regulator and have no more issues. I put the regulator at the campground spigot, run the white hose to the AS, add a filter and 90 degree elbow at the connection. Works great.
05-06-2016, 11:33 AM
#52
2023 Interstate 19
Scottsdale
Is the built in regulator adjustable?
05-06-2016, 01:11 PM
#53
Corona
Nope. It's preset and not adjustable.
10-21-2019, 05:04 PM
#54
2019 27' Globetrotter
Salem
, Oregon
Built in regulator defective. Can they be repaired or need to replace. Can not get adequate pressure through mine. Just a very small stream as each fixture.
Dave
04-24-2023, 12:03 PM
#55
Euless
, TX
It is not a regulator on the airstream and if it leaks, the water will not show up at the little hole on the outside. It will leak on the inside. It is trash. Take it apart and trace the hole. It is blocked. It will not regulate.
04-24-2023, 02:05 PM
#56
Spokane
What?
04-25-2023, 06:29 AM
#57
Euless
, TX
Several things here. First, the valve is not a regulator, it is a limiting valve. It does not regulate. It is like a pop off valve and it does not drain out the little weep hole on the outside. It may default at a certain pres. they mostly just leak on the inside.
The drain hole is also blocked, inside.
04-25-2023, 06:31 AM
#58
Euless
, TX
No and it does not work. I told airstream and nothing.
04-25-2023, 07:40 AM
#59
2008 22' Safari
Spicewood (W of Austin)
VacuumKing….you are responding to a post that was made in 2019. I doubt he/she is still around.
04-26-2023, 06:59 AM
#60
Euless
, TX
Thank you. I just get board and thanks for reading it.
