Old 05-04-2016, 07:28 AM   #43
dznf0g's Avatar
Oswego , Illinois
Originally Posted by cactusjk View Post
Thanks!
Actually, 65psi...I posted it upstream....duh.
-Rich-
Old 05-04-2016, 07:43 AM   #44
2015 23' Flying Cloud
Livermore , California
I am thinking of going with a 2 filter setup with a 55 psi external regulator for the campsite water source. Any problems with that approach with respect to flow, etc?
cactusjk is offline   Reply With Quote
Old 05-04-2016, 08:02 AM   #45
Long Island , New York
We always use an external water pressure regulator at the hose bib, and make sure we turn off the hose bib when we leave the site.
Old 05-04-2016, 08:25 AM   #46
dznf0g's Avatar
Oswego , Illinois
Nope, I run an adjustable Watts regulator at the bib, through a water softener and filter...all at 60psi and everything is fine with flow and pressure at the AS fixtures.
-Rich-
Old 05-04-2016, 08:45 AM   #47
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
I have been using one of those non-adjustable ones and have not been very happy with how low the water pressure is. I just bought this one (http://www.amazon.com/Pressure-Regul...ater+regulator). What a difference! We now have good pressure inside again. I did some testing and found that a pressure setting of 60 psi is good and if you turn on the water pump at this setting, it will still run a short time. If I am understanding this, does that mean the water pressure using just the water pump is about 65psi.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 05-04-2016, 09:11 AM   #48
dznf0g's Avatar
Oswego , Illinois
That's a reasonable assumption, but if you look up the specs for your particular brand and model of pump, they usually tell you XX gallons of flow, at XX PSI.
-Rich-
Old 05-04-2016, 01:07 PM   #49
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Thanks Rich, I appreciate the reply.
Julia & Bob
W/ Deedee & Boo
AIR #30685
Old 05-04-2016, 01:13 PM   #50
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
We see the larger regulators with a gauge included. Are the union style regulators of such poor quality that one of these upgraded regulators is a good idea? Appreciate any technical input, including life span. Thanks. Pat
Old 05-04-2016, 10:30 PM   #51
2007 22' International CCD
The cheap brass fixed regulators don't allow as much flow as the ones with a gage on them. I had one, and it didn't flow enough volume for the tankless water heater to work right at a campground with somewhat low water pressure. Tossed the darn thing, got the better regulator and have no more issues. I put the regulator at the campground spigot, run the white hose to the AS, add a filter and 90 degree elbow at the connection. Works great.
KE4GNK/AE
Old 05-06-2016, 11:33 AM   #52
Is the built in regulator adjustable?
Old 05-06-2016, 01:11 PM   #53
Nope. It's preset and not adjustable.
KE4GNK/AE
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Water pressure regulator? yukionna Fresh Water Systems 7 06-16-2010 10:03 PM
Help!! Need access water pressure regulator Crawdad Fresh Water Systems 5 07-15-2007 02:16 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
Any PLUMBERS out there?? Pressure regulator, water pump questions SmokelessJoe Water Heaters, Filters & Pumps 65 01-11-2007 03:01 PM
