Old 04-30-2016, 10:54 AM   #29
2015 23' Flying Cloud
Livermore , California
Has anything changed on newer (2015) AS when it comes to water pressure regulation? Is it still a good idea to use an external pressure regulator to protect the hose, etc?
cactusjk is offline   Reply With Quote
Old 04-30-2016, 01:54 PM   #30
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Yes, we use an external pressure regulator to protect the hose and external water filter. Otherwise, we wouldn't bother - we just dislike the potential of a burst hose and gallons of potable water all over the campsite.
Rocinante is our 2014 International Signature 27FB
Old 04-30-2016, 07:56 PM   #31
I saw that on your blog. Do you still like the SS one you list?
I am thinking of going with the lower end Camco blue filter for now.
Old 04-30-2016, 08:09 PM   #32
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I don't think a second pressure regulator is needed, and I don't think it will protect the hose.
I think the hose bursts from sitting in the hot sun with a volume of water trapped in the hose between the campground backflow prevention valve and your Airstream's closed water system. The water expands and the hose material is the weakest link.
A better hose protection device that also protects your Airstream plumbing from expansion damage is a water pressure accumulator mounted inside the Airstream and connected to your Airstream plumbing.
Doug and Cheryl
Old 04-30-2016, 10:24 PM   #33
Rivet Slave
Rocinante's Avatar
Water Pressure Regulator Device
Yes, we still like the SS Camco regulator. Again, it's nice to have, not necessarily required. We like to think it protects the hose, etc. and so we use it. Pretty cheap insurance, really.
Dkottum may be right about the accumulator, btw. We have no idea.
Old 04-30-2016, 10:32 PM   #34
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, Doug; I have been in camp grounds that have around 100 lbs of water pressure and for these I use an external water pressure regulator. This is to protect my hose and filter. Do you really think an accumulator will prevent this? I don't know the rating of a water hose, but I think 100 lbs is too much for one.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-01-2016, 01:46 PM   #35
1989 32' Excella
Sharon Springs , New York
How long has AS been using the internal regulator, what is its expected service life, where is it located and can it be replaced by an AS owner?
James
MAJORJDB is offline   Reply With Quote
Old 05-01-2016, 04:09 PM   #36
Salem , Oregon
Images: 18
James
Hi, I don't know how long Airstream has been using a built-in water pressure regulator, but it is located, and part of, your water inlet.
2005 Safari 25-B
Old 05-01-2016, 08:23 PM   #37
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
AS has these parts for around $40, we were at a State Park last summer and before I knew it, it blew out the AS regulator. Stop in Denver and fix in 1 hour, now I check water at all camp grounds, and all better to be safe than sorry.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 05-03-2016, 07:48 PM   #38
What pressure is the AS regulator set at?
Old 05-03-2016, 08:15 PM   #39
dznf0g's Avatar
Oswego , Illinois
60 psi, iirc.
-Rich-
Old 05-03-2016, 08:22 PM   #40
Thanks!
Originally Posted by dznf0g View Post
60 psi, iirc.
Old 05-03-2016, 08:35 PM   #41
dkottum's Avatar
Bob, I think it will certainly help. I think an RV water pressure regulator at the spigot controls pressure only while there is water flowing through it. After that the campground back flow prevention device locks the water in your hose and the pressure throughout your hose and Airstream water system equalizes right to the faucets.
Then if there is thermal expansion in system due to heating of the hose in the sun and heating in the water heater, and there will be, it is up to the elusive air "bubble" in the water heater to take up that expansion. Or relief by the water heater thermal/pressure relief valve.
If these fail to protect your system and hose from thermal expansion, a water pressure accumulator can provide expansion space.
Doug and Cheryl
Old 05-04-2016, 07:03 AM   #42
dames7's Avatar
GILBERT , Arizona
45 psi, ck with /AS
David & Nancy Ames
2015 FC 25' RB
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Water pressure regulator? yukionna Fresh Water Systems 7 06-16-2010 10:03 PM
Help!! Need access water pressure regulator Crawdad Fresh Water Systems 5 07-15-2007 02:16 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
Any PLUMBERS out there?? Pressure regulator, water pump questions SmokelessJoe Water Heaters, Filters & Pumps 65 01-11-2007 03:01 PM
