Old 12-22-2012, 08:48 AM   #1
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
water pressure regulator
Hi guys,
we are getting ready to set the plumbing in the Avion and one of the thing that we will like to replace is the Water Pressure Regulator.
Looking for some of them at HD and Lowes and they all look pretty similar.
So just any pre-set to 45psi with a back flow valve will do it? any suggestions will be great to help in the decision process.
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 12-22-2012, 09:07 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
You could just install an Airstream water connection and have a clean installation. Item 14765 on this site
Inland RV Center Inc.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Old 12-22-2012, 11:27 AM   #3
Chatthayer's Avatar
1972 25' Tradewind
Chattanooga , Tennessee
Images: 21
The external ones are $11-14at an rv store
Steve and Tobie Thayer
chatthayer@gmail.com
Chatthayer is offline   Reply With Quote
Old 12-22-2012, 11:51 AM   #4
1973 31' Sovereign
2007 20' Safari SE
well this is the original design that uses the same door for water city connection and fresh water tank fill up, so I really don't want to make a new whole in the trailer and really don't trust the little plastic ones
ID:	175036   Click image for larger version
2 chronicles 7:14
Old 12-22-2012, 11:53 AM   #5
HowieE's Avatar
Images: 12
Keep one thing in mind. This thing, sold as a pressure regulator, will do NOTHING.
Camco 40055 Brass Water Pressure Regulator - Walmart.com
A regulator has to have a means of stopping flow in order to control pressure once the set pressure is reached. This thing are an open bore and can not control pressure. At best they might control flow volume in an full flow request but I doubt that would even work.
2004 Excursion 4x4
Old 12-22-2012, 12:20 PM   #6
HowieE's Avatar
Images: 12
What you have pictured is a standard Watts Pressure Regulator available at any plumbing supply house. Generally they are adjustable as noted by the screw on the top.
2004 Excursion 4x4
Old 12-22-2012, 03:51 PM   #7
1988 32' Excella
Robbinsville , New Jersey
True and that one says it has a range of 25-75psi they are normally preset to 45psi. I can't tell from the picture if it is for 1/2" or 3/4" pipe just get one with the same size fittings, unless it's 1/2" and you want to get 3/4" and adapt it down(this would help eliminate a flow restriction since a regulator can't flow as well as a hollow pipe).
Old 12-22-2012, 04:56 PM   #8
1981 31' Excella II
New Market , Alabama
Do you know that the regulator you have is bad. I don't trust any of them unless you have a gage down stream to tell you if it is working.
Perry
Old 12-22-2012, 05:12 PM   #9
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
I've used this one a few times. If you are replacing all the plumbing with PEX it is a good fit. Your old regulator may be good, but like Perry says, you'd have to check it with a gauge to be certain. They do sell regulators with a gauge attached.
Lance
Top is offline   Reply With Quote
Old 12-22-2012, 08:48 PM   #10
1973 31' Sovereign
2007 20' Safari SE
Hi Guys
thanks for all the inputs.
We are not aware of the regulator condition, BTW any way to test it?
we will be re-doing everything on pex so we are thinking that replacing the existing as an extra insurance.
We were thinking on getting one with a gauge and wondering about the chance to have a "remote gauge" so the pressure can be easily monitored.
2 chronicles 7:14
Old 12-22-2012, 09:02 PM   #11
1973 31' Sovereign
2007 20' Safari SE
How about this one, can the gauge be re-located for monitoring purposes?
Or maybe we should ask if the gauge indicates the incoming or the outgoing pressure into the system?
2 chronicles 7:14
Old 12-22-2012, 09:04 PM   #12
1988 32' Excella
A remote gauge is fairly easy just run a line to where you want it put a fitting on the end for the gauge to screw into. It is a little harder setting it up for winterizing need to have a T-fitting for the gauge and a valve or leading to a faucet ect... so that line can be drained, blown out and/or filled with anti-freeze.
Old 12-24-2012, 06:46 PM   #13
1981 31' Excella II
Well the gage is on the outlet so it reads the regulated pressure not the supply pressure.
Perry
Old 12-24-2012, 07:46 PM   #14
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Where was the source for the pressure regulator with gage with hose fittings?
