"Reason not to use"
They are not adjustable. Preset to 40-50 PSI. Modern trailer plumbing can safely and easily handle up to 80 plus. Standard sized dual water filter canister systems function at an optimum 60 PSI according to The RV Water Filter Store customer service line.
Actually, this is incorrect. The Shurflo units Airstream installs as standard these days is 65 psi.
If you say so that must be correct. 🤔
MICHAEL
