Old 04-24-2016, 06:14 AM   #1
1971 31' Excella 500
santa rosa , California
water pressure Issue
Hi folks
I have a 31ft 1972 Airstream. The water pressure is great in the bathroom and really weak in the kitchen sink. Any thoughts?
lornahanen is offline   Reply With Quote
Old 04-24-2016, 06:47 AM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
There may be a plugged cold water filter under the kitchen sink. In our 2015 23D International Serenity we see a small cylinder in line with the water line about 1.5" in diameter and about seven or eight inches long. In the 2014 Classic there is a more elaborate system with a twist off filter like in a home under the kitchen sink.
Also there could be a filter screen at the end of the faucet that is plugged with stuff.
switz is offline   Reply With Quote
Old 04-24-2016, 07:25 AM   #3
A W Warn's Avatar
2000 25' Safari
Try removing the strainer from the faucet. Sometimes scale from the water heater will block the flow.
Old 05-03-2016, 10:19 AM   #4
1995 30' Cutter Bus LE
Mesa , Arizona
Water coming from bathroom toilet area to bedroom. Carpet all wet. Not flushing toilet yet fresh water keeps coming. What might be the problem?
Swtcat2u is offline   Reply With Quote
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 19 07-03-2019 09:19 AM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
