Old 11-20-2008, 10:02 PM   #15
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Old 11-20-2008, 10:07 PM   #16
2005 30' Classic
Images: 12
You're welcome. Hope it helps. Brand is Zurn.
"Hot and cold potable plumbing manifold designed to reduce installation time and save energy by running dedicated lines to each plumbing fixture. Manifolds without valves let the consumer choose the type of connections that best suit the specific job. Comes ready for installation and can be easily installed by mounting it in an accessible area and selecting the appropriate size line and connector to run to each fixture (supply lines and connectors are sold separately). Manufactured using an engineered polymer. Factory tested to ensure reliable service."
GetOutDoors is offline   Reply With Quote
Old 11-20-2008, 11:19 PM   #17
cameront120's Avatar
1972 25' Tradewind
Seatech and Sharkbite also makes manifolds, if you're interested.
North Vancouver, BC
Needing manifold vacuum for brakes wayne.yl Brakes & Brake Controllers 26 03-08-2007 09:25 AM
exhaust manifold john roeder Mechanics Corner - Engines, Transmission & More... 31 01-18-2007 07:35 AM
Manifold..or ALANSD Mechanics Corner - Engines, Transmission & More... 5 12-23-2004 07:49 AM
Right cast iron manifold free Astrodokk Airstream Motorhome Forums 1 10-19-2003 10:04 PM
Spacer on exhaust manifold needs replacing. rdm Mechanics Corner - Engines, Transmission & More... 30 11-19-2002 04:14 PM
