Old 02-17-2013, 04:13 PM   #1
1966 22' Safari
Matagorda , Texas
Water lines - 1966 Safari
I have a 66 safari.what water lines that are there run behind the kitchen cabinets.they are PVC.should the water and vent pipes be in the coach or between the floor and bottom pan.
Greg
Greg65 is offline   Reply With Quote
Old 02-17-2013, 06:14 PM   #2
1965 30' Sovereign
Ottumwa , Iowa
all mine were above the floor dont know if that was right someone worked on mine a bit before i bought it. I have all mine out remolding my camper and i have decided that mine are going to stay above so if i need to make a repair it will be easy to get to. Im just going to run them along the wall and build a box around them from the couch to the cabinets to keep them hid
cjohnson is offline   Reply With Quote
Old 02-17-2013, 07:20 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Water lines are normally above the floor in the spaces that stay warm when you have the furnace running. Plus they are much easier to access. No removing belly pan to gain access.
TG Twinkie is online now   Reply With Quote
Old 02-17-2013, 08:48 PM   #4
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
The original water lines in our '66 Safari were copper and above the floor. PO had let them freeze, so we cut them out and replaced with PEX--also above the floor. If yours are PVC, they must have been replaced sometime in the trailer's history.
Old 02-18-2013, 06:20 AM   #5
1966 22' Safari
Matagorda , Texas
Thanks for the info.this is definately a learning experience.
1966, 1966 safari
Black Water Flush Blocked ElliotA Plumbing - Systems & Fixtures 6 04-01-2017 06:26 PM
Water tank-weep holes-mystery leak(s). Gator113 Fresh Water Systems 9 09-21-2011 02:39 PM
New '67 Safari black water tank? losfew Waste Systems, Tanks & Totes 1 09-06-2011 06:19 PM
Water pump running with no water! Michigander Fresh Water Systems 11 07-25-2011 03:04 PM
Tepid water, lots of air bubbles Spot Water Heaters, Filters & Pumps 23 06-16-2011 08:35 AM
