Old 07-18-2015, 07:25 PM   #1
loislane's Avatar
2014 23' International
Saint louis , Missouri
Water leak inside trailer - kitchen sink cabinet
Name:	ImageUploadedByAirstream Forums1437268647.488662.jpg
We have water coming out from under the sink of our 2014 23 ft Intl - nothing in the cabinet seems wet - none of the pipes from the sink - everything seems dry under the bed near the hot water heater - and in access cabinets under pantry and closet. Any ideas on where this could be coming from? Click image for larger version
Name:	ImageUploadedByAirstream Forums1437269080.724428.jpg
LoisLane
2014 23d Int'l CCD
TV: Toyota 4runner
"Homer"
loislane is offline   Reply With Quote
Old 07-18-2015, 07:28 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Check toilet flush valve.
CRH is offline   Reply With Quote
Old 07-18-2015, 07:54 PM   #3
loislane's Avatar
Hey @CRH my husband says that the toilet seems unlikely because it's on the other side of the trailer - he thinks it may have something to do with the fresh water tank but we aren't sure. Have you had a similar problem caused by the toilet flush valve?
LoisLane
2014 23d Int'l CCD
TV: Toyota 4runner
"Homer"
Old 07-18-2015, 08:02 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
Yes...I just replaced my flush valve this week. Couldn't fig out why hallway carpet was getting wet. I thought toilet line was loose and tightened. I left water hooked up at home two days with dry carpet. Went on next trip and had wet spot within hours. Found valve only leaked when the toilet was flushed.
Old 07-18-2015, 08:04 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
Do you have a water purifier under the kitchen sink. Not having the cartridge one correctly will give you a wet floor, too...been there. Done that.
Old 07-18-2015, 08:09 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my trailer leaked under the sink during our Alaska trip; The sink drain pipes were loose. They tighten by hand and were loose. Reach under the sink and check the drain pipes. No tools needed.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-18-2015, 09:11 PM   #7
loislane's Avatar
Hey all thanks for the replies.
So a few more details - there is nothing wet under the sink - the pipes are tight and leak free and we do have a water purifier but nothing seems wet around it. Just a small amount of water coming out at that seam at the front of the sink. We have vinyl floor and don't see anything happening when we flush toilet.
Tonight we turned off all the water and turned off the pump (we had had it on while traveling) and drained some water out of the fresh water tank and it seems to have stopped. We think this only happens on travel days - we've noticed it before as a wet front door mat. Also it rained the last two days - so we're wondering if water is collecting somewhere or if the water is sloshing out of the fresh water tank while driving - does that make any sense?
LoisLane
2014 23d Int'l CCD
TV: Toyota 4runner
"Homer"
Old 07-18-2015, 09:41 PM   #8
Salem , Oregon
Images: 18
Hi, my trailer had a fresh water leak when brand new; We noticed water on the floor right after we filled the tank for the first time. What I found was when the factory installed the vinyl flooring, while trimming the vinyl, they accidentally cut my filler tube. You could tell from the line where they trimmed the vinyl was in line with the cut in the hose.
2005 Safari 25-B
Old 07-19-2015, 11:58 AM   #9
1Boyscout's Avatar
2015 28' International
Edmond , Oklahoma
Do you have the outside backflush hookup to flush out the black tank..?
OURS leaked there uder the siik cabinet.
1Boyscout is offline   Reply With Quote
Old 07-19-2015, 12:33 PM   #10
2015 30' International
Piedmont , South Carolina
We had exactly the same problem but also saw water under the sink in our trash can. Our water filter was installed backwards (per the arrows on each end indicating correct flow). Turned it the correct way and added plumbers tape on the threads to fix the leak. We also saw water under the front door mat.
The leak would only occur when water was under pressure (outside source or pump on).
vsgunte is offline   Reply With Quote
Old 07-19-2015, 03:14 PM   #11
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
I do not leave the WP on....when sleeping or when no-one is in the trailer.
Old 07-19-2015, 03:27 PM   #12
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
I had the same leak when I first got my 23', it was the water filter connection. One side of it was loose and missing the end seal. My undersink cabinet shelf wasn't wet, the water seeped down the wall behind the filter and ran down. Don't see how it could be anything other than that section of the plumbing or possibly the drain pipe, as referred to above, since there is nothing else under there.
Although I guess anything is possible, with the fresh water tank being towards the rear of the trailer and under the floor, might be hard for it to slosh water all way to the front. Good luck in tracking it down.
'01 16' Bambi --- Swee' Pea
'13 23D International --- Trixy
'09 Silverado --- Big Bertha
Adoptee -- '78 Argosy 24' Moho -- Big Girl
tinbender is offline   Reply With Quote
Old 07-19-2015, 10:26 PM   #13
loislane's Avatar
Thanks so much @vsgunte and @tinbender - you guys saved our trip! We were thinking we'd have to go back to Jackson Center for some big repairs (we were just there a little over a week ago for our first time) but after your posts I urged Jim to look at the water filter and sure enough it was dripping just like tinbender said so we removed the filter and hooked up to city water again and hooray no leaks! We are thinking we may just leave that filter off for now - we didn't use one on our 19 ft and we did fine without it. Since you both kept yours in we'd be open to hearing pros and cons of leaving it off.
LoisLane
2014 23d Int'l CCD
TV: Toyota 4runner
"Homer"
Shower grey water reflux from kitchen sink jordandvm 2002 - 2005 International 12 12-17-2011 02:10 PM
Kitchen Sink Hot Water wlgilbert40 Fresh Water Systems 6 05-04-2009 10:05 AM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
not enough hot water from kitchen sink faucet codybear Fresh Water Systems 3 01-24-2006 10:20 PM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
