Old 02-14-2013, 07:02 AM   #1
2011 16' Sport
Avon , Colorado
Water leak from sink area
2011 16" sport water leak under sink leaking out front side of tire on metal lip how do you get to see it front is covered with wood panel only leaks when doing dishes thanks
mcfur is offline   Reply With Quote
Old 02-14-2013, 08:18 AM   #2
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
We get a leak once in a while too. First culprit is the P trap as pots and pans in there will push up against the drains which will loosen and leak. Second and very common is the sink sprayer where the line connects to the spray head. The supply lines to the faucet are a possible source but less likely to loosen. Empty the cabinet, dry every thing with towels and then run the water while looking underneath the sink with a good flashlight. Take a paper towel and feel around all supply lines and drain tubes. Most likely a simple tightening of lines or drains will do it.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 02-15-2013, 05:46 PM   #3
2011 16' Sport
Avon , Colorado
Smile
Good idea, many thanks
Old 02-16-2013, 07:09 AM   #4
Portland , Oregon
You're welcome. Let me know what it was. Just curious.
Tepid water, lots of air bubbles Spot Water Heaters, Filters & Pumps 23 06-16-2011 08:35 AM
Help-dewinterizing and no water off freshwater tank bonginator Water Heaters, Filters & Pumps 6 06-12-2011 08:37 PM
Water supply question at a state park. meadowlm General Repair Forum 6 06-07-2011 10:57 PM
'74 Trade Wind..broken water line, continued Ameliasdad Fresh Water Systems 1 04-07-2011 01:10 PM
Leak in Refrigerator Outside Compartment 4RXLA Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 04-03-2011 07:33 PM
